House Alarm
Started by Auto Addict, 08 April 2015, 10:14:02
Auto Addict
With the alarm deactivated, can I isolate the mains and change the battery?
I like red cars
Normally, if the alarm is just unset, the tamper circuits are still active, so the alarm will sound if you remove the cover from the control panel to replace the battery.
You need to put it into "engineer mode" (apologies to MarkDTM ::) )
the alarming man
you really don't need to isolate mains to replace a battery as you may lose all the programming but as Kevin said you would need to put it into engineers mode to stop the alarm activating in tamper...your user code will stop it going off but that being said depending on the programming you may be able to reset it using your code... :y
Auto Addict
Ah! That might be difficult, as I haven't got the engineer code :(
I like red cars
the alarming man
as I said your user code will stop it going off and you may be able to reset it using your user code :y
Auto Addict
Quote from: the alarming man on 08 April 2015, 10:36:47
I like red cars
tigers_gonads
What make of control panel have you got ?
Pull the lid and the alarm will sound, then enter your code to turn it off.
Change the battery and replace the lid, reset the panel
My advice would be to get the installation instructions and reset the system to factory (there is pretty much always a way ;-) ), then re-program with your own codes etc so you have full control and access.
tigers_gonads
Quote from: Marks DTM Calib on 08 April 2015, 10:48:03
95% of the time, yes
Some panels require a engineers code for global tamper reset hence the question
Quote from: tigers_gonads on 08 April 2015, 10:52:06
Always ways around that one to  :y
the alarming man
the only way around it is if the panel is programmed for engineer reset is either an engineer reset or a factory restart and that s not always possible as most manufactures include a function to allow you to lock the NVM which means the original engineers code stays in....and the only way around that is a approach the  manufacture and send the board back to them....
Or use a suitable programmer to get into the NVM and modify it......not difficult  :y
tigers_gonads
Quote from: Marks DTM Calib on 08 April 2015, 13:14:33
This is mr custard we are talking about  ::) ;D
As said
Give us the panel make and model then more accurate advice can be given
Mr Custard has more of a technical background then you would think...... :y ;)
tigers_gonads
Quote from: Marks DTM Calib on 08 April 2015, 13:28:12
Then no doubt Barry will come back and call me  a cheeky idiot then  ;D
It's called banter but don't worry  ::)
I take it your hard at work .............
Me, I'm sat outside having numerous pints of cold BEER and thinking of you lot sweating away  ;D
Hugs and kisses ....... The Gonad Family  :-*
