wanted hose clip
Started by pauls, 08 April 2015, 23:01:36
pauls
Need the clip that is attached to the header tank and holds the two waterpipes
sjc
Guessing this is for one of the 2 small diameter pipes, not for the larger diameter one at the bottom of the header tank?
I'm sure I'll have both sizes kicking about so let me know which you need.
It's the support bracket that locates the plumbing to/from the auxiliary pump on the inner wing  :y
sjc
Ah, sorry don't have one of those - false alarm.
