Dodgy wiring
Started by omegod, 09 April 2015, 13:42:31
omegod
Just discovered this mess in our office, 6 unfixed wall sockets wired in series to power all the IT eqp't. Is this normal practice  :o
Any evidence of electrical testing recently... those green tested on such and such a date by so and so stickers :-\
If not it's almost certaily illegal... but nothing a quick call to the HSE can't sort out :D
Quote from: Taxi Al on 09 April 2015, 13:48:29
Equipment is PAT tested, but IIRC the sockets it's plugged into aren't..
[edit] Looks fine to me, I mean.. it's not on fire, is it? ;D
tigers_gonads
Eh no
For info only, you can have as many 13amp sockets in series as you want but the run must start with a fuse spur with a 13amp fuse as protection for that run.
Looking at that (from my phone), it looks like the cable was twin and earth but has had the outer gray insulation cut back (again naughty if not in a enclosure).
Also they should be securely mounted on a board or solid structure.
If one of my lads had done that, he would be out of work and unemployable as a sparky.
omegod
Appliances are PAT tested but on closer inspection the cables are coming up through the floor through a piece of roughly sawn drainpipe that is chafing through the insulation. It will all be replaced  ::)
Gaffers
Nah, that looks absolutely fine.  Nowt wrong with that buddy ;D
Steve B
Quote from: Monsieur Guffer on 09 April 2015, 14:59:59
You sure on that  :-\  Do you not think a few wire ties to clean it up.. Someone could trip over that lot  :y
Just refit the panel and stop worrying.
Although it might be a good idea to check the fire extinguishers and evacuation procedure.
Just in case, you understand.
Terbs
In my many years in the decorating game, I saw that situation more times than I have had hot dinners. It seemed to be the norm where IT was concerned. ;D
chrisgixer
Isnt that nearly all Ethernet?
Plug it into the mains and see. ;D
hawke113a
Looks like back of my pc desk lol  :D
biggriffin
Don't worry about it,just carry on.
Hoof'land storeman.
The Sheriff
Behind my telly/computer always ends up looking like that, as I try out new fixes and leave the old stuff there. It's perfectly ok until I try to work out what it was I was trying to do in the first place.
I have a large bag in the garage crammed with all the old leads and connectors I ever used. Must be 10 or 12 scart leads in there. Might come in handy.  ;D
Quote from: STMO on 11 April 2015, 21:57:46
Sounds like much of the content in my garage, oh and the loft and cupboard under the stairs etc........... ::) ::) ;)
I imagine that lot used to be enclosed in a power pole and someone wanted to move their desk two inches so the pole was ripped down and the chaos you see there is the result.
