Author Topic: 2.6 V6 front engine noise  (Read 2552 times)
Dave_G
  • Nottingham
    • 2002 2.6 Elite Estate
« on: 11 April 2015, 11:25:56 »
Hi all,
I'm getting an odd noise which is difficult to pin down - coming from the front of the engine definitely but can't make out where. Sounds like a mix of chafing and rattling at the same time as if something's loose or wobbly.
I was thinking of removing the aux belt then running the engine again to double-check that something along this belt path is the culprit.
Would this be the right way to proceed, do you reckon?
Cheers,
flyer 0712
Re: 2.6 V6 front engine noise
« Reply #1 on: 11 April 2015, 11:31:09 »
Old trick...length of wood to your ear and onto each area where noise is coming from until you hear where it is loudest....may help you pin it down  :y
Dave_G
  • Nottingham
« Reply #2 on: 11 April 2015, 11:37:39 »
Not a bad idea. Thanks
I'll do that first and if I get a positive(ish) location then I'll take the belt off to get closer to it.
Hoping it's around here and not cam belt related...
Dave_G
  • Nottingham
« Reply #3 on: 11 April 2015, 12:13:02 »
Ha! It's the water pump pulley. Seems slightly wobbly and rough, but no water leakage though.
Runs sweet with the belt off.
I'll check for a maintenance guide.
« Reply #4 on: 11 April 2015, 14:33:00 »
Easy enough to change... when was the cambelt last done? As might be prudent to do that at same time...
Dave_G
  • Nottingham
« Reply #5 on: 15 April 2015, 07:44:40 »
Sorry for the delay replying Taxi Al, work happened.
Cambelt was changed only 15k ago, and I needed to get back on the road asap, so just changed the pump.
Struggled a bit because there's no maintenance guide for it, and the cambelt DVD is sold out - but I tried to remember what Mark DTM did when he changed the cambelt last. Seems to have gone on OK, but I had to do it through the front cambelt cover hole.
Just got to refill this morning then hopefully good to go. Thanks again.
Cheers
