Author Topic: Rev Counter flickering (part 2)  (Read 7962 times)
MV6Matt
  • London
    • No car since 2022....
« on: 12 April 2015, 00:40:39 »
............Hmmm
what can I say..?
Having driven a few days ago and finding all was well (see previous thread), jumped in the car and off out today.
Flickering Rev counter and now, no speedo. The mileage keeps counting so something's still connected.
No dash lights coming on. I did notice the temp gauge going down (then up again) and that happened once more. Never seen that before.
Too late to paper clip test, but that might be something, plus the alternator check that Al suggested.
Otherwise, any ideas?
(thanks Ian)
Re: Rev Counter flickering (part 2)
« Reply #1 on: 12 April 2015, 03:45:53 »
Sounds like a voltage issue... possibly a failed regulator allowing overcharging...
Do the alternator/battery check as per Kevins guide before you break summat ::)
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #2 on: 12 April 2015, 07:09:09 »
It's something internal to the clock unit. I had exactly the same, you'll probably find it will get progressively worse until the dials fail altogether.
...although I never had a temp gauge issue.
chrisgixer
  • Woking ham
  • Banned
MV6Matt
  • London
« Reply #4 on: 12 April 2015, 08:37:08 »
Same as this?
http://www.omegaowners.com/forum/index.php?topic=126806.0
Looking like a swap then, :'( but I'll do Kev's test as well (Not having looked yet though so may be outwith my scope.....)
Anyone bring a 98 mfl dial cluster to the May bank Holiday meet?  :-\
(thanks Ian)
MV6Matt
  • London
« Reply #5 on: 12 April 2015, 09:14:49 »
There's an Alternator replacement guide and a repairing the Alternator in the Maintainace Guides section, but not a one by Kev for checking. ???
Am I in the right place?
(thanks Ian)
MV6Matt
  • London
« Reply #6 on: 12 April 2015, 09:21:09 »
 Or do you mean this one:- Battery, Charging and Starting diagnosis? :-[
(thanks Ian)
« Reply #7 on: 12 April 2015, 09:24:39 »
chrisgixer
  • Woking ham
  • Banned
chrisgixer
  • Woking ham
  • Banned
« Reply #9 on: 12 April 2015, 09:29:47 »
Can't do any harm to check it, but if your symptoms match mine, it's not a charging/battery issue.
MV6Matt
  • London
« Reply #10 on: 12 April 2015, 10:04:27 »
This is where I think it'll be. I don't have a multimeter so I'll have to borrow one I guess.
If I can find a replacement dial set can anyone help change it at the May B/H meet?
Cheers all
Matthew
(thanks Ian)
MV6Matt
  • London
« Reply #11 on: 13 April 2015, 16:51:19 »
Got myself a new instrument panel today.
Does anyone know if it is possible to swap stuff over so I can leave the mileage intact?
It looks dismantleable - but I don't want to take a working one apart if it's not put back togetherable.
Hopefully,
MV6Matt :-\
(thanks Ian)
chrisgixer
  • Woking ham
  • Banned
« Reply #12 on: 13 April 2015, 18:01:23 »
Dunno, but I'm selling t shirts for fitting clocks without fitting known working bulbs first. :-[ ;D
MV6Matt
  • London
« Reply #13 on: 13 April 2015, 18:05:09 »
 ;D ::) 8)
(thanks Ian)
« Reply #14 on: 13 April 2015, 20:08:38 »
Hopefully,
MV6Matt :-\
Needs to be from same engine group... Say dbw v6... Otherwise might not work... Ideally same age/engine/gearbox...
As for mileage, remove odo reset pin, unclip unit from facia trim, carefully reset mileage, refit
panel and pin :y
