Author Topic: can get in drivers side  (Read 1952 times)
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« on: 12 April 2015, 19:54:45 »
My solenoid was playing up but I could just unlock with the remote and open the door with the key. Now when I open the drivers door with the key it won't open at all. So today I had to get in via the passenger side.
I can actually unlock the car with the key but the door lock stay down on the drivers door.
Any ideas? :)
« Last Edit: 12 April 2015, 20:03:36 by Dan282 »
Re: can get in drivers side
« Reply #1 on: 12 April 2015, 20:07:33 »
Any ideas? :)
Perfectly normal given the failed solenoid...
As for ideas... er, change the solenoid ::)
You can either repair and refit your existing one, or simply fit A N Other front door solenoid :y
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #2 on: 12 April 2015, 20:28:21 »
Can I do it even if I can't open the drivers door though as I'm assuming that the door card will need to be removed?
« Reply #3 on: 12 April 2015, 20:29:49 »
If you can unlock the drivers door with the key, it should open :-\
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 12 April 2015, 20:34:47 »
I assume you are saying that the rest of the doors unlock with the key operating in the drivers door lock, but the drivers door remains locked with the plunger down :-\
If so it sounds like a mechanical linkage issue. :y
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #5 on: 12 April 2015, 21:18:23 »
Yes mate. I've managed to open the front door now although the door pin is still down.
« Reply #6 on: 12 April 2015, 21:32:56 »
Pin normally stays down once solenoid has failed :y
When you remove the lock mechanism to replace the solenoid,  you will be able to systematically work through all the linkages to check that they work and also to lubricate the lock mechanism as required :y
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #7 on: 12 April 2015, 21:37:41 »
Superb. Cheers for that  :) :y
