Clay bar kit
Started by EMD, 17 April 2015, 19:19:14
EMD
Can anyone recommend a good clay bar kit ? Loads on the market so confuddled as what to buy  :-\
Omegatitis
Mr.OmegaMan
Used to use various clay bars before I heard about this on a detailing forum.
Farecla 7191A G3 Pro Body Prep Clay Mitt by Farecla http://www.amazon.co.uk/dp/B00K4UVUEG/ref=cm_sw_r_udp_awd_9Hvmvb0QM8AM4
Far more simpler and quicker with the same level results.
chrisgixer
Too much effort ......too little return.
A comely full-breasted wench with a bucket of warm soapy water and a sponge is what you need. ::) ::) ;)
4x4
Maguires clay bar kit is good  :y
driver115
As I have recently acquired another vehicle , thanks for this information and I`ll give the product a try :y
Steve B
Quote from: driver115 on 17 April 2015, 20:55:31
What you mean the  full-breasted wench   :-\
chrisgixer
Clay bar double barrelled sling shots next? ;D
EMD
Quote from: 4x4 on 17 April 2015, 20:53:37
Yep , seeing as i already have the Maguires polish mite as well go for that  :) Had a go with Tcut , hard work but did bring the bonnet up a bit better so hope this clay bar will bring out the metallic a bit better  :)
Omegatitis
4x4
Need clay bar kit,which includes detailer which you use as a lubricant,paint cleaner,polish and wax,get it all when halfords do there special offers over bank holiday.
EMD
#10
Ive just got some headlight lens repair polish so will crack on with that tomorrow  :)
So bring your seat and polishing cloths  :P
Omegatitis
GastronomicKleptomaniac
Bilt hamber autoclay. By far the best value, you only need water as lube (steady now). :y
the alarming man
dodo juice kit is good enough and come with lub :y
I tried Bilt Hamber clay on several cars and couldn't see any improvement, so save the extra hour per car.
I've been using a clay cloth and it's the dogs twitcher for a novice like me :y
