Author Topic: slow coolant leak  (Read 5020 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
slow coolant leak
« on: 25 April 2015, 20:49:36 »
Hello, i noticed i'm getting a slow drip from the radiator drain plug, can this be fixed or is it possible to just rep[lace valve by its self ,thanks for any help
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: slow coolant leak
« Reply #1 on: 25 April 2015, 20:53:32 »
There is two black little O rings inside that red tap which you can get from main dealer  :y
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 25 April 2015, 21:06:12 »
How does it come apart BT?
Steve B
  • Leicestershire
« Reply #3 on: 25 April 2015, 21:14:48 »
Unscrew it and once it pulls out a little, Pull it and you will have it in your hand  :y
« Reply #4 on: 25 April 2015, 21:16:49 »
That radiator looks familiar  ::)
My rad tape was bing leaky about a month ago, I just nipped it up a bit more. If it leaks again, I'll be putting new o rings as suggested above  :y
Steve B
  • Leicestershire
« Reply #5 on: 25 April 2015, 21:18:53 »
Two new O rings sorted that leak Above  :y
Toledodude1973
  • IPSWICH U.K.
« Reply #6 on: 25 April 2015, 21:20:30 »
Thank you , thats brilliant ,i'll get the o rings and drain coolant ,then remove red valve bit to sort it
« Reply #7 on: 25 April 2015, 22:15:57 »
Apparently the drain plug has been superceded by one with an integral seal...
pauls
  • By the sea minehead
    • Bmw x3
« Reply #8 on: 25 April 2015, 22:48:29 »
Thats correct new number is 93194704
« Reply #9 on: 25 April 2015, 23:14:24 »
Steve B
  • Leicestershire
« Reply #10 on: 25 April 2015, 23:44:38 »
No way are them two O rings Unique to VX only..My two came out of a Box of Assorted O rings  :y
http://www.omegaowners.com/forum/index.php?topic=102794.0
Edit... And they are in that box somewhere..
http://www.ebay.co.uk/itm/225pc-Rubber-O-Ring-seals-Tap-Washers-Gasket-Assortment-plumbing-petrol-diesel-/141211297303?pt=LH_DefaultDomain_3&hash=item20e0d96617
Bet VX will sting you for a tenner for the tap  :y
« Last Edit: 25 April 2015, 23:57:49 by BIGtime »
pauls
    • Bmw x3
« Reply #11 on: 26 April 2015, 00:18:40 »
Vx tap is 2.47 :y
Steve B
  • Leicestershire
« Reply #12 on: 26 April 2015, 00:21:28 »
Vx tap is 2.47 :y
Sooner spend the extra 8p And get loads of marriage proposal rings thrown in with the deal  ;D ;D ;D
Toledodude1973
  • IPSWICH U.K.
« Reply #13 on: 26 April 2015, 20:52:31 »
Thanks all, the pictures are really helpful ,i have an "o" ring set so i'll try that route first.....OOF is on form :y
