Author Topic: oil leak  (Read 5728 times)
EMD
  • Noofhampton
    • 95t
Re: oil leak
« Reply #15 on: 09 May 2015, 19:41:49 »
Where the cam covers gaskets / sealant ect done on a cold engine ? And did you let it all settle/cure overnight ?
Omegatitis
tec2tec
  • high wycombe
    • omega 2.6 v6
Re: oil leak
« Reply #16 on: 09 May 2015, 19:48:50 »
no it was all done at the wycombe meet
powerslinky
Re: oil leak
« Reply #17 on: 09 May 2015, 19:52:56 »
Is this not the one that Taxi Al & Nick done at the Wycombe meet last week ?  If so , I'm sure replacement covers were used .
I had a 2.5 MFL Elite  where I done the cam covers 3 times with 2 sets of new gaskets & a set of good used cam covers  . .
Just could not stop it leaking  . . . not pouring out but a few drips on the floor after about 20 mins.. sold it in the end  ::)
Edit : must type faster ::) ::)
tec2tec
  • high wycombe
    • omega 2.6 v6
Re: oil leak
« Reply #18 on: 09 May 2015, 19:54:26 »
its starting to look like it will going soon
4x4
Re: oil leak
« Reply #19 on: 09 May 2015, 20:17:47 »
Only 224 posts to go before you can sell it on here.  :-X
tec2tec
  • high wycombe
    • omega 2.6 v6
Re: oil leak
« Reply #20 on: 09 May 2015, 20:31:08 »
or just park it up with number in window :'(
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: oil leak
« Reply #21 on: 09 May 2015, 21:38:00 »
Compression test next then... ?
See if it's over pressurising the crank case.
tec2tec
  • high wycombe
    • omega 2.6 v6
Re: oil leak
« Reply #22 on: 09 May 2015, 21:40:42 »
do you know any one that does that or is it garage time
chrisgixer
  • Woking ham
  • Banned
Re: oil leak
« Reply #23 on: 09 May 2015, 21:42:36 »
No. It doesn't need that amount of teme to cure. Black goo takes about 15mins to go off, so by the time it's reassembled it's ready to go. Something else is at play here IMO.
chrisgixer
  • Woking ham
  • Banned
Re: oil leak
« Reply #24 on: 10 May 2015, 00:00:16 »
There's a few here, but before bothering them we need some honest answers. Is the oil level correct? Ie, NOT above the top mark on the dipstick when hot?  Has anyone worked on it since the meet? Are the breathers properly clear when blowing through BOTH ways via the breather pipes at the back of the plenum?
Forgive the direct approach but if members are going out of their way to help they might not be best pleased if the basics are not right. Applogies again, but I hope that's understandable?
    • 530D M Sport, 330i Coupe
Re: oil leak
« Reply #25 on: 10 May 2015, 08:06:44 »
Is the oil pressure valve working?
tec2tec
  • high wycombe
    • omega 2.6 v6
Re: oil leak
« Reply #26 on: 10 May 2015, 11:30:15 »
not sure and how would i find it
