Does Andy C ...
Started by 05omegav6, 27 April 2015, 00:41:32
Reading section 10, I reckon my solution would be a perfectly acceptable repair, as the complete load bearing assembly has been replaced...
Yeh, I think it's patching is the problem, not panel replacement.
henryd
Quote from: Taxi Al on 29 April 2015, 20:35:38
It's technically panel replacement rather than a patch repair, so be interesting to get a definitive answer from Henry D :y
A patch repair continuously welded is an acceptable repair anywhere on the shell,its suspension arms and the like that shouldn't be welded
other rides
andyc
I can check for you tomorrow
Thetford. Norfolk
symes
Quote from: henryd on 29 April 2015, 21:05:28
better to cut out complete than patch--having to replace patches on cars--as metal under patch can corrode-then your back to square one again
I would rough cut one from scrapper and then drill spot welds and then install
henryd
Quote from: symes on 29 April 2015, 22:32:34
You are right it is much better to cut out and replace with new tin,sadly when its an old shitter of a Ford Ka that needs a ticket and the owner thinks it'll cost a tenner then standards may have to slip a bit !!.
other rides
Much more eloquently put than I managed :y
Quote from: henryd on 29 April 2015, 22:46:48
Your seeing them in that state to then.....I had one two months ago where the only thing holding the filler in place was the filler neck.....and Ford sell a special repair panel just for such an issue!
henryd
Quote from: Marks DTM Calib on 30 April 2015, 11:02:26
Down here in the salt air they are truly shocking,had a mint looking 1 owner 40k miles 06 plate in for mot tother day and had to patch both sills,lady owner was a little pissed to say the least :-X
other rides
