Does Andy C ...
Started by 05omegav6, 27 April 2015, 00:41:32
... or anyone else for that matter, know if either 9117704/9117705 are still available,  or better still, if this...
... is available as a repair panel for the Omega A/Senator A/B :-\
Rods2
If you Google 'Omega B 9117704' a US and a number of East European suppliers are listed.
Steve B
Al if not, could you not drill all them spot welds out on a breaker
Quote from: Rods2 on 27 April 2015, 19:55:06
Two for sale, one is $228 plus shipping, tother is 15000 ru plus shipping :-\
The actual piece in question is a modest part of that whole assembly... if such a thing exists, the corresponding sub assembly might be available as a repair panel for an earlier model :-\
minifreek
Can it not be welded/patched...?
D.I.L.L.I.G.A.F...
Quote from: minifreek on 29 April 2015, 16:11:19
You haven't seen Terrys picture of the actual damage, have you... :D
Given its function it would be better to replace as a single unit ;)
It wouldn't be a difficult piece to make, even if you had to reverse engineer it from the other side.
That turret is actually three bits of metal... The main pressing, a lower cup and upper cup, all welded together where the shock bolts through :y
That actually makes it easier;  the cups provide the strength for the shock, and the shape of the pressing does the rest.
The turret is certainly easier to remove/refit than the inner wing assembly and the repair should be more substantial than trying to patch a knackered one... Also makes it feasible to use second hand one...
terry paget
Quote from: Taxi Al on 29 April 2015, 16:13:54
Here's the hole, with the mounting perched on the wing
https://www.dropbox.com/s/cmuktdl1ovd0adj/opelSTRUThole1.jpg?dl=0
I don't think your allowed to patch anything less than 30mm from a suspension component anyway... certainly any corrosion that weakens an area within that zone in a way that would weaken the mounting point is a no no at an MOT.
Thanks Terry :y
Quote from: VXL V6 on 29 April 2015, 19:23:37
Looking at Terrys pic, his might not be savable then... Unless the crack on the out board edge could be lost when a replacement turret is welded back in...
Thinking drill the spot welds out, cleaning up the wheel side and then plug and seam welding the replacement panel into position :-\
Finish off with seam sealer and paint...
Actually I meant 30cm!
I think one of the MOT testers on here needs to clarify the situation, as I understand it, any repair needs to extend as far as sound part of a load bearing member. Looks like there are different approaches for spot welded panels etc.
It's technically panel replacement rather than a patch repair, so be interesting to get a definitive answer from Henry D :y
