EGR cleaning
Started by Shackeng, 29 April 2015, 09:30:21
Shackeng
I just read this out of interest. Any comments with relevance to either the V6 or the TD?
http://autorepair.about.com/od/regularmaintenance/a/Cleaning-Your-Dirty-Egr-Valve.htm
Terbs
I think that advice has been given to me by members on here mate.....
However, if I knew what is was and where it was, I would probably have a go at it ;D
Diamond Black Geezer
Best advice regarding egr cleaning I can give is take the rubber stuff off before using carb cleaner, as carb cleaner degrades the rubber - after soaking overnight the rubber was like warm liquorice! I have more spares than I know what to do with at present, so not an issue, but if this is your only egr valve, beware, as a poor seal going into the plenum will cause air leaks and idle issues.
Webby the Bear
Quote from: Shackeng on 29 April 2015, 09:30:21
Y comment is the best thing to do. . . Blank the f.....r off  :y
RIP Paul Lovejoy
Shackeng
Quote from: Webby the Bear on 29 April 2015, 17:52:29
Yes I know that is frequently recommended. What effect does doing this have on the, ever more stringent, emissions test? :-\
Webby the Bear
Nothing at all mate. The gas in questions s nox. And that's nit tested on an mot  :y
RIP Paul Lovejoy
Quote from: Diamond Black Geezer on 29 April 2015, 11:13:48
Above quote true for ICV, not EGR. Apologies for any confusion! Long day! Agree with Webby, just blank it off, easiest simplest solution
Shackeng
Quote from: Webby the Bear on 30 April 2015, 00:20:20
Nothing at all mate. The gas in questions s nox. And that's not tested on an mot :y
Yet!
Reading the recent press on NOx emissions, I would bet they will test for this in the next year or two, and as I hope to run my Omegas for a few more years, I shall keep my EGR's for the moment. :y
They will need some very large and very expensive kit to test for it.....including a rolling road to load the engine up  :y
So I would not worry.
Oh yes, for cleaning EGR valves, oven cleaner is your friend but, don't leave it in it for to long as it will attack the alloy eventually.
minifreek
I blanked my EGR off and it feels quicker....?
D.I.L.L.I.G.A.F...
Webby the Bear
Part throttle will feel quicker. No inert gases going to the cylinders  :y
RIP Paul Lovejoy
minifreek
Naaah it feels loads quicker through the whole rev range, especially when the G cams switch on...
D.I.L.L.I.G.A.F...
Quote from: Webby the Bear on 30 April 2015, 22:13:56
Er no, the only gain will be a slight improvement in throttle response when going from light load to boot down due to not having to wait for the exhaust EGR to close and exhaust gases in the inlet to dissipate.......all assuming it was working perfectly in the first place.  :y
Webby the Bear
RIP Paul Lovejoy
