Whine'y diff noise type thing ?
Started by EMD, 29 April 2015, 13:19:27
EMD
On my mot it says rear wheel bearing slight whine . So had both rear bearings checked and no noise but the front nearside wheel bearing was knackered  :( Still got whine'y noise like diff sound ? Diff full of oil so lost as to what it is  :-\
Could it be something like prop bearing knackered  :-\
Omegatitis
Sticking pads, poorly adjusted/sticking handbrake shoes/mech, diff worn, discs/drums worn, diff mounts worn, general drivetrain noise, sticky imagination...
Of course, it could simply be a wheel bearing ::)
The Sheriff
It's not a 1.4 astra is it? They whine all the time..from everywhere  ;D
Quote from: STMO on 29 April 2015, 16:43:39
Including from the driver's seat.
EMD
Quote from: Taxi Al on 29 April 2015, 16:01:16
The diff mounts are the only thing i have not checked  :(
Omegatitis
The Sheriff
Quote from: Nick W on 29 April 2015, 17:18:24
OOOOOOO...bitch.
chrisgixer
Could be. Could be that cat has climed in the boot. ;D
EMD
Best stuff some sawdust in the diff  :(
Omegatitis
biggriffin
Quote from: chrisgixer on 29 April 2015, 21:07:28
Nah he was in hoof-land tother day,it's all them bottles of our water,he nicked ;D
Hoof'land storeman.
chrisgixer
Well that'll bloody do it, right enough ;D
symes
Quote from: EMD on 29 April 2015, 13:19:27
check center bearing  :y
Mine used to have a slight whine on over run, the bearing on the input to the diff had play in it. There's a rolling torque figure for it somewhere, but I just gently nipped it up till the play had gone, then did it again a few weeks later with with a bit of Locktite on the nut to stop it slackening of again  ;)
EMD
Quote from: symes on 29 April 2015, 22:36:20
Quote from: Andy B on 30 April 2015, 00:41:43
Thats what this does andy  :y Will have a look .
Thing is the advisory on the last mot is totally wrong , its not the rear wheel bearing at all  ::) Someone was trying to get some work out of it  >:(
Omegatitis
Quote from: EMD on 30 April 2015, 06:23:21.....
Fo the past 15+ years, my cars have gone for MOT at a MOT station that doesn't do repairs ...... financially, he couldn't give a monkey's whether it passes or not  ;)
