Cam belt a 2.2
Started by joff, 02 May 2015, 20:02:30
joff
How much work to do the cam belt on a 2.2 petrol FL, brother wants his doing and I have only done the V6's on the Omega, do I need a looking kit ? ???
deviator
Is it not a chain on the 2.2 petrol?
flyer 0712
No..its a belt...every 40,000 miles or i believe 4 years. :y
deviator
Quote from: flyer 0712 on 02 May 2015, 20:07:12
I stand corrected, I avoided the 2.2 because I thought it was the y22se.
4x4
Need cam locking kit ,change water pump and coolant while your at it,all goes ok 1.5-3 hrs depending on how easy bolts come undone on cam belt cover and back plate
Also you will have to remove cam pulleys to get rear cam belt covers off as the waterpump bolts are hidden behind it.
joff
Quote from: 4x4 on 02 May 2015, 20:23:56
what's in the locking kit on that one, are they twin cam on the 4 pots?
QuoteAlso you will have to remove cam pulleys to get rear cam belt covers off as the waterpump bolts are hidden behind it.
steve6367
Twin Cam 'locking kit' is just a plastic wedge that I would say makes is easier, but not essential.
Quote from: joff on 02 May 2015, 20:29:25
steve6367
#9
Below is what you will be looking at, you can see the water pump and wedge in place - not sure about some of the comments further up, its really simple  :y
steve6367
joff
Thanks for all the above, as for the cam pulleys being in the way I think that's the Vectra engine, I know the 1.9 Dti is like that.
what about adjustment on the tensioner is it like the V6
Have a read of Haynes re the 2.0 16v belt... Desmond is fundamentally the same, and of course get the OOF dvd too :y
joff
Quote from: Taxi Al on 02 May 2015, 22:41:34
For the 2.2?
joff
Quote from: joff on 02 May 2015, 22:50:45
For the 2.2?
Just looked at the Shop :y
