Diff oil additives ?
Started by EMD, 03 May 2015, 08:43:36
EMD
Going to replace my diff oil in the V6 but i want to use some sort of additive to quieten the backlash i seem to be getting . Any recommendation oil additive to use ?  :-\ Not much available in the local factors  :(
Omegatitis
chrisgixer
http://www.omegaowners.com/forum/index.php?topic=90526.0
Only the LSD has an additive. I's suggest the issue is a mechanical one, that needs repair or replacing.
EMD
Damn , something else . Will get there in the end
Omegatitis
Quote from: EMD on 03 May 2015, 10:29:29
Hard to fix for 99p methinks. :'(
chrisgixer
Used difs are fairly cheap in non LSD form, and fairly easy to swap out. Just make sure it's from the same engine to get the right gearing. Might be worth doing the seals before install as well.
EMD
#5
Quote from: chrisgixer on 03 May 2015, 11:50:38
Sounds like the diff but definitly not the gearbox or
wheel bearings .  Serek checked all that .. its like a wirring sound
that goes away under load slightly .
Not the handbrake either ..
Omegatitis
Steve B
Quote from: EMD on 03 May 2015, 12:53:22
Your list is growing just like mine Did  ;D ;D Told you there is no such thing as a Mint omega out there  :y
EMD
Mint on the outside ha ha  ;D Ill get there  :-X
Omegatitis
