Your list of omega jobs.
Started by chrisgixer, 03 May 2015, 13:32:13
chrisgixer
This should keep Stmo amused for a while. ;D
Your list of jobs that need doing in order of priority.
Mine;
Sort the woom woom woom noise at the rear. Brakes I think.  :-\
Re fit poly donuts
Fit Pilot super sports on the front.
Find a better park pilot speaker solution.
Keep it clean
Change the oil
Put the elite memory loom in the mv6 door currently fitted and
Come up with an Elite / Mv6 seat combo that allows memory.
Mv8
Create some time to
Fit Uj's to rack.
Make a log fanimold around the rack.
Etc....
hawke113a
rebuild my v6...upgrade with 3ltr cams...apply f/l door cards to my pre f/l...wash and wax...
Migv6 le Frog Fan
The list is currently so long that I dare not think about it. Its too depressing. Im hoping to find the time / funds / energy over the summer to do the big jobs, such as handling so bad the car is almost undriveable, misfire on gas, rusty n/s wheelarch,and cambelt slightly overdue on time.
Neglect an Omega for a year and it will punish you. ::)
minifreek
Finish repairing the O/S rear arch
Wash and polish
Change oil
D.I.L.L.I.G.A.F...
EMD
Sort woom woom bzzz noise from the back .
Cam belt change
Crank seal
Spent the last 2 weeks doing 2 oil changes , new exhaust and wheel bearing .
Oh and clean out the blocked breathers from previous owner  ::)
Washed n waxed
Thats it , nothing challenging  :)
Omegatitis
SMD
Buy a nice black one (but a nice one would suffice)
The cambelt is due, and the crank oil-seal is leaking.
It needs new droplinks.
I need to figure out how to remove the covers off my replacement mirrors so I can paint them silver.
The OSR wheelarch still needs to be repaired.
It could do with a clean.
GastronomicKleptomaniac
I think the server will melt if I post mine up...
Finish collecting parts for the black estate suspension, fix the coolant leak, service it and replace anything else likely to break on it before finally sorting the body work ::)
Get the windscreen changed on the white one, then MoT it and finally get it decorated :-\
Oh and remove the glovebox from one of them before coming to the Wycombe meet...  :D
Steve B
Quote from: Taxi Al on 03 May 2015, 22:27:34
Why.. no fan or hog
Oil changes on both, 3.2 very over-due.
Cambelt on 3.2, that's over due too.
Bit of noise from rear passenger on 2.2, almost drop link type sound. Only on very rough roads. Need to investigate.
Quote from: BIGtime on 03 May 2015, 23:08:46
Why.. no fan or hog
Neither, more of an exchange thing :y
chrisgixer
Quote from: Taxi Al on 03 May 2015, 23:37:55
Why.. no fan or hog
Telematics?
Quote from: chrisgixer on 03 May 2015, 23:39:37
Why.. no fan or hog
Telematics?
I should have done all sorts but I didn't even clean it!! Never mind... I'll park it in the corner tomorrow :-[ ::)
