Don't own a torque wrench...
Started by The Sheriff, 04 May 2015, 20:57:16
The Sheriff
...so, when I was finishing off my wheel nuts today, I made a little 'click-click' noise with the final grunt. Is that acceptable?
EMD
Quote from: STMO on 04 May 2015, 20:57:16
That will be your knees  :D ;D
Omegatitis
The Sheriff
Quote from: EMD on 04 May 2015, 21:05:29
You're not wrong  ;D
Delroy47
The Sheriff
Quote from: Delroy47 on 04 May 2015, 21:15:05
So you improvised  ;D
It's what the man at kwik fit does, I've seen him.  :y
chrisgixer
Quote from: STMO on 04 May 2015, 21:31:19
Yeah, with every turn of his windy. :D
chrisgixer
I guess that depends if the wheels fall off or not. Or weather you can get them undone again next time.  Locking wheel nuts? Or is there honour amongst thieves round your way? ;D
minifreek
The click click is metal on metal so yeah plenty tight enough... but it could also be your knees, its normally my back that makes noises like that when I stand up LOL
D.I.L.L.I.G.A.F...
Diamond Black Geezer
Best advice I heard was always put wheel nuts/studs on by pulling up, and undo by pushing down. Pull up as hard as you like, as tight as you feel comfy with, but that as you will always guarantee that they'll come undone again.  :)
The 'click click' in this case may well have been a camera lens shutter of a pervert hiding in the bushes taking shots of your rear end as you were bending over your car. Keep an eye out, there are bad people out there  :D
tigers_gonads
Torque upto "just before you shit yourself" then another 1/4 of a turn  :D
Quote from: Diamond Black Geezer on 05 May 2015, 10:20:14
Other way round, always put on but pushing down as the torque is limited by your body weight, undone by pulling up as you use the power of your legs muscles which are capable of lifting your body weight and some.
But either way, unless you use the wheel brace that comes with the car, you may well struggle at the side of the road
zirk
Never used a torque wrench on any wheel nuts in my entire life, never had any problems yet. ;)
Final last kick on the squeak seems to do the trick.  :y
EMD
Take it to Quickflip , you will never get the nuts off again  ;D
Omegatitis
Quote from: Marks DTM Calib on 05 May 2015, 12:14:30
Ah, yes, that's the one!  :y
