Drill set.
Started by Field Marshal Dr. Opti, 07 May 2015, 14:51:39
I have just purchased a 15 piece Irwin drill set, HSS titanium.
Sizes range from 1.5mm to 10mm.
I'm informed this will also be fine for drilling wood.
Truth or boll*cks?
zirk
Quote from: zirk on 07 May 2015, 15:01:53
Yep, be fine.  :y
I've always used wood bits before.....for wood. :y
Always a preference to use wood bits as they have a different cutting face (reduces chipping as they are designed to cut through the wood grain), generally a centre point to aid location and often a deeper scroll (at the expense of strength which is not so important with wood) for removal of the drilled wood from the hole.
ronnyd
Sometimes standard drill bits tend to scorch the wood if you,re pushing too hard or the revs of the drill are too fast. :y
The Sheriff
Quote from: ronnyd on 07 May 2015, 16:33:08
I love the smell of burnt wood in the morning.
ronnyd
Apocalypse now, great film
EMD
Quote from: STMO on 07 May 2015, 16:35:18
                       _o_
Yep , woodbine  ::)
What are you planning to make or drill Mr Opti  :-\
Omegatitis
Mrs Opti in law... :D
The Sheriff
Quote from: EMD on 07 May 2015, 17:00:12
                       _o_
Yep , woodbine  ::)
Or, as Boris described your avatar, Ajockalypse now. ;D
