is two stories too much!
Started by Impact Pete, 08 May 2015, 20:03:49
Impact Pete
www.impactcls.co.uk - Flight Case Manufacture
You could build one with pallets.  ;)  There are plenty of designs and step by step instructions about on the web. The one below is quite simple but you'll get the idea.  :y
http://builtbykids.com/how-we-built-our-pallet-playhouse/
Impact Pete
Quote from: Sir Tigger on 08 May 2015, 21:16:19
not exactly pretty! I had thought about using the wood from pallets but with 2 year olds splinters from rough sawn pallet wood would not go down well, and sanding it down would take an age, cheapest way though  :)
Kate
Quote from: Impact Pete on 08 May 2015, 21:22:09
Not exactly pallet-shal. ;D
The Sheriff
Quote from: Kate on 08 May 2015, 21:23:59
Dear oh dear.  ;D
There are plenty of designs available on the internet and you could line it with ply, tongue & groove or something similar.  Cheap and easy, just needs a bit of imagination!  :y
tigers_gonads
Whatever happened to the days when you just gave them a couple of cardboard boxes, a roll of sticky tape to play with and tell them to use there imagination  ;D
Impact Pete
Quote from: tigers_gonads on 08 May 2015, 21:43:53
I suspect my eldest (nearly 3) would tape the carboard to my youngest 1 or similar!
tigers_gonads
Quote from: Impact Pete on 08 May 2015, 21:47:31
I suspect my eldest (nearly 3) would tape the cardboard to my youngest 1 or similar!
Nothing wrong with that
Give me 5 minutes with them and i'll tell then about some of the things I used to do to my younger sister when we was kids  ;)
Then again, maybe not  :-X ;D ;D ;D
If you do build it Pete, take some pickys for us all to see  :y
Quote from: Impact Pete on 08 May 2015, 20:03:49
I wanted to build my 2 little boys a small outdoor playhouse then when surfing Amazon I have come across ridiculous wooden mansions making our own home look small
I'm now thinking a bit bigger! plans started out at a door 2 windows 4 walls and a roof, now I'm thinking 2 stories with staircase! is that going too far! I draw the line at running water and electrics  :)
I know there are some wonderful ones that you can buy, but there is something about 'making' your kids something to play in, a bit of effort and all that, you can even get them involved helping to build it. A fab way of Dad and Daughter bonding, I built this for Miss Vamps, when she was 3............. :y :y
http://www.smythstoys.com/uk/en-gb/outdoor/c-646/play-houses-tents/p-3485/little-tikes-country-cottage-pink/?gclid=COOzyqORs8UCFUTnwgodX0MASw
lesv6
we had one like that as a field shelter for the horses
Impact Pete
Quote from: tigers_gonads on 08 May 2015, 21:53:13
will do  :y
ronnyd
Looks as bad a our local pish filled bus shelter. :P
