semi or full synthetic oil ??
Started by mick-1975, 10 May 2015, 16:05:51
mick-1975
Am I right in saying that the vectra c 2.2 sri direct takes fully synthetic oil 5/40.? Or have you guys recommend something else . Millage is 119000.  Mick
biggriffin
Thought it was 5w30 fully sympathetic
Hoof'land storeman.
chrisgixer
Either semi of full lymphatic. But given the more sensible short changes that are considered good servicing, I don't see the point in the more expensive full lympfnode tbh.
Webby the Bear
plus the semi will be more likely to stay in the engine on an older car than the slippery full fat stuff  :y
RIP Paul Lovejoy
chrisgixer
Yes if going for the oil filter collapsing 20k changes, go full uthinasia. Defo. :y
mick-1975
Thanks I'll get a tub of semi synthetic then and filter. And possibly flush it out as well to be Certain it's clean .
chrisgixer
Steady with the flush. It can clog the arteries and the oil pic up. Better to change it for semi synthesiser for a few k, then fit the fully uthinised after that, with new filter again.
Webby the Bear
plus the lifter treatment to clear a bit more shite :)
RIP Paul Lovejoy
the alarming man
Quote from: biggriffin on 10 May 2015, 16:49:37
it is and that is what Vauxhall states should be used :y
Webby the Bear
At the garage we use 5w30 semi and 5w30 full fat. Semi goes in old cars and shite boxes, fully goes in nice cars. Simplez  ;D
RIP Paul Lovejoy
chrisgixer
Semi being 10w40. Fully being 5w30. For GM spec.
biggriffin
Quote from: Webby the Bear on 10 May 2015, 17:56:37
Fully sympathetic would be better in higher mileage cars as it holds its viscosity,better than semi.
Hoof'land storeman.
chrisgixer
Quote from: biggriffin on 10 May 2015, 18:01:15
Nope. Fully is thinner. From the outset. Another reason why 10w40 is better on higher mileage cars...for omegas. Certainly.
biggriffin
Using oil that's to heavy in a car recommended to use a 5w/30 can cause sludge issues.
Hoof'land storeman.
Webby the Bear
Quote from: chrisgixer on 10 May 2015, 18:03:37
That's my understanding hence the garages approach  :y
RIP Paul Lovejoy
