Author Topic: Interior light and total closure  (Read 1964 times)
iwasthestig
  • Omega 3.0 MV6
« on: 16 May 2015, 19:33:50 »
My omega has had a couple of wierd problems since ive owned it, if I open any of the doors other than the drivers my interior light doesn't work although the puddle lights do, I've tested the door switches but they all seem to be working fine, also the light doesn't come on with the headlight switch, as well as that total closure doesn't seem to work either even if I reset the windows, I've had op com on and it brought up a fault code on the alam ecu saying the system has low voltage?
Anybody have any ideas?
« Last Edit: 16 May 2015, 19:35:39 by iwasthestig »
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: Interior light and total closure
« Reply #1 on: 19 May 2015, 08:43:46 »
Does the total closure work if you hold the key in the lock position...?
D.I.L.L.I.G.A.F...
iwasthestig
  • Omega 3.0 MV6
« Reply #2 on: 19 May 2015, 19:33:54 »
No not at all, quite annoying really as I used to use it all the time on my old one  :-[
