Sealey 3 tonne Trolley Jack
Started by Sir Tigger KC, 16 May 2015, 21:40:36
Webby the Bear
This is the one you want ST.....
http://www.tool-net.co.uk/p-346066/clarke-ctj3000g.html?gclid=Cj0KEQjw-OCqBRDXmIWvveLE3_cBEiQAZWfImRDpwzM9vnARFL99kZwigBIdEDpVwXyWmtvoop5rEeEaAsmy8P8HAQ
You'll be surprised at the size of it when it comes!  :o
Really great for easy jacking up. But just got to practise lowering it as it suffers a little bit like AndyB says....lowering valve either on or off lol
However, having used it a lot I've got the nack to it now and I can lower slowly  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 17 May 2015, 11:12:58
That's what I have; a 3tonne jack needs to be lot more robust than the first one mentioned. It's bloody heavy, which is a good thing until you have to carry it indoors!
Quote from: Webby the Bear on 17 May 2015, 11:12:58..
It was the best description I could come up with
Webby the Bear
I wasn't ''lol''ing at your description andy.....only the fact that youre right...its either on or off!!! sills nearly touched the floor first time I let it down  ;D
RIP Paul Lovejoy
Quote from: Webby the Bear on 17 May 2015, 12:07:44
but it was a naff description .......  ;D ;D
SMD
I have the same jack as webster and mine too has the on and off lowering valve.
X30XE
http://www.justoffbase.co.uk/Trolley-Jack-Yankee-3ton-Standard-Chassis-Sealey-3000CXD
Slightly cheaper and perfectly adequate.  Needs a rubber pad or ice hockey puck off the bay to compliment it.  :y :y
Omegatitis : [in remission]
chrisgixer
Quote from: X30XE on 17 May 2015, 12:44:35
Yep, exactly the same as the oppsin appalling one Daz had. The ome I have in black. The one TB has. Utter rubbish I'm afraid.
Yours might be ok, but give it time. I suppose they might the odd one that is passable on a production run. ;D
driver115
got the sealey jack about a year ago /similar /same price - functional does the job, but unsure of long term reliability for the low price paid
Quote from: chrisgixer on 17 May 2015, 13:46:05
The one TB has.
HAD, dear fellow, had. It is no more :D
I wouldn't go that far. Its just there is so much better available for around the same price.
chrisgixer
Three I've encountered, all shite. I guess there must be a good one somewhere ?
Certainly not something I'd ever recommend to anyone else, given said experiences. :)
Diamond Black Geezer
What about the Halfords ones? No idea about other stuff, but very pleased with the tools, or is this another bit of badge engineering?
I'm going to hold on for a bit as there's a really good auction near here where all sorts of workshop equipment turns up.   :y
So I'll see what I can find there.  ;)
Quote from: Diamond Black Geezer on 19 May 2015, 14:36:32
AFAIK, Halfords only sell toy ones, often RAC branded?
The Sheriff
A jack is something I use if I have a puncture. Don't think I've had my scissor jack out for years.
