Sealey 3 tonne Trolley Jack
Started by Sir Tigger KC, 16 May 2015, 21:40:36
Quote from: Sir Tigger on 16 May 2015, 21:40:36
I need a new jack and this Sealey seems a good buy. Anyone got one and are they any good?  ::)  TIA!  :y
http://www.ebay.co.uk/itm/Sealey-1153CX-Long-Chassis-Heavy-Duty-3-Tonne-Yankee-Car-Van-Trolley-Jack-/121649349295?pt=LH_DefaultDomain_3&hash=item1c52ddc2af
If it's anything like the one Daz brought along to Newent the other year, the lowering valve is very much ON or OFF ..... very difficult to lower the car gently
chrisgixer
Is Tigger asking us if that turd can be polished?
It might be ok for the first dozen uses. But would need perfectly level and smooth ground to avoid folding up sideways eventually. So you'll likely need another next year, in which case buy a decent one in the first place.
[stuck record mode on] Buy cheap, buy twice..... [click] Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click] [repeat to fade...........] (sigh....)
I need a new jack and ....
I can recommend the Arcan jack I bought from Costco a while ago ....... depends obviously on whether you're a member, know one or if Costco still have any  http://www.costco.co.uk/view/product/uk_catalog/cos_8,cos_8.5,cos_8.5.10/900930
chrisgixer
Attention OOF. Attention OOF.
CHRISGIXER AGREES WITH ANDY B  >:(
;D
tidla
In local stock 3 weeks ago, and yes a good lightweight jack.
Quote from: chrisgixer on 16 May 2015, 22:11:49
;D
??? :o :o........................ ;)
Clucking Bell... And it's not even Friday :o
Quote from: chrisgixer on 16 May 2015, 22:04:05
I take it you don't rate Sealey products then Chris?  ::)
Quote from: Andy B on 16 May 2015, 22:09:44
They vary almost on a yearly basis.  But always good quality.  My Arcan XL3000 actually survived the "incident" a couple of years back (although the handle didn't), not that I'd ever use/trust it again.
The lightweight one I bought to replace it is also excellent, and doesn't break my gonads when lifting ;D
Quote from: Sir Tigger on 17 May 2015, 01:16:28
Sealey import and badge the same Chinese stuff as many other brands. Clarke are another who import and badge exactly the same stuff.
In the case of jacks, I've had both a Clarke (exact one also available as Sealey) and a couple of Arcan ones, and the Clarke one was a not a patch on the Arcan ones, yet similarish price.
omegod
I have the Arcan 2 tonne one, I'd hardly describe it as lightweight at 25 kilos but it's a hell of a jack ! Think is was £80 ish in jan
chrisgixer
Sorry I thought we where talking about sealey jacks...? From first hand experience of mine and other members at various meets actually using they're jacks....They're shite Tigger!
Plus yours is a a poxy narrow bodied one. Slightest uneven ground and those gay little wheels dig in and the whole body twists. It will get permanently bent.
Plus, with those, you've got to fish about unplugging the handle to let the thing down.
If you want a bullit proof garage Jack get the arcan three ton. Wide low body. Wide big wheels. Smooth lowering action. Good reliable cog mechanism. Impossible to bend. Takes omegas with ease.
If you want a good portable Jack. Get the 1.5 tone TB has. Exact same design but in alloy. With a single roller at the front iirc. ...?
Arcan! Not sealey ::)
You think all sealey products are good?
chrisgixer
Should add my sealey one (exact same body as TB's and Daz's at Newent) branded fast lift and painted black, is hopeless. Immediately displayed issues with lifting a full stroke of the handle, so is actually not fast lift at all. New seals and oil after a year, no better. Hair trigger dropping the car. The body is man enough though so twice the size of your one.
Daz's sealey? ;D hair trigger drop. Cogs in the release mechanism failed almost every time. Eventually Jimbobs car got stuck and we couldn't get it down without going under the car to fiddle with that same hair trigger mechanism.
They're shit Tigger. Plus, that one, the body isn't man enough.
Thanks for the consumer advice chaps, I'll stay away from this one then.  ::)
