Author Topic: wheels  (Read 4317 times)
djmoorey
  • cwmbran south wales
    • omega elite v6 auto
wheels
« on: 17 May 2015, 11:58:16 »
Hi can anyone tell me if the alloy wheels on my omega elite will fit onto a nissan primastar van which is the same as a vivaro the omega is a 1999 and the van is a 06 model cheers
Re: wheels
« Reply #1 on: 17 May 2015, 13:26:40 »
What size tyres are on each?  The PCD of Omega is 110, with 5 studs, if this is different, then they definitely won't fit. Beyond that, the rolling diameter of tyre needs to be same, and the ET needs to be correct for the vehicle/wheelsize.
In a nutshell, its very, very unlikely ;)
djmoorey
Re: wheels
« Reply #2 on: 17 May 2015, 13:41:58 »
omega trye size is 225/55 zr 16 5 stud primaster are 205/65 r 16c 5 stud
Re: wheels
« Reply #3 on: 17 May 2015, 14:13:59 »
The actual tyre size isn't that relevant and both might be 5 stud, but are the PCDs the same, are the offsets similar & the bores of the centres need to be the same
Re: wheels
« Reply #4 on: 17 May 2015, 15:29:38 »
Not going to happen as long as you have a hole in your arse :y
X30XE
  • UK
    • 740i,728i,S320 & Disco
Re: wheels
« Reply #5 on: 17 May 2015, 15:43:55 »
Seconded... nor even if you don't !  ;D
Omegatitis : [in remission]
Re: wheels
« Reply #6 on: 18 May 2015, 17:12:35 »
Rim width will play a part in the required offset :)
Re: wheels
« Reply #7 on: 18 May 2015, 17:55:05 »
With a pcd of 118, an offset of ET50 and a centre bore of about 70 mm, I stand by my earlier observation ;D
Re: wheels
« Reply #8 on: 18 May 2015, 17:56:15 »
As suspected, foreskin ear warmers would have to be invented first
4x4
Re: wheels
« Reply #9 on: 18 May 2015, 18:16:39 »
No they wont fit,plenty of sites to look on to find out the correct information,and less than 2 mins of your time  :y
beefyecosse
  • newmains lanarkshire
    • 2.6 cdx saloon
Re: wheels
« Reply #10 on: 21 May 2015, 23:04:45 »
have seen a few with bmw wheels fitted using wobble bolts to go from 5x118 pcd to bmw 5x120 pcd insignia wheels should fit aswell
Re: wheels
« Reply #11 on: 21 May 2015, 23:43:48 »
Wobble bolts are for retarded idiotts to stop their brains from falling off :-X
X30XE
  • UK
Re: wheels
« Reply #12 on: 22 May 2015, 00:01:32 »
A bit strong  :D
But yes, Wobble bolts... the clue is in the name... Wheels and wobble do not make good bedfellows  :y
