Author Topic: Is this what I think it is...?  (Read 4513 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 17 May 2015, 12:30:27 »
On my 2.5TD, is this the HBV? It's dripping coolant :-\
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: Is this what I think it is...?
« Reply #1 on: 17 May 2015, 12:32:21 »
That looks like its a air con pipe. The HBV is at the back of the engine just below windscreen, drivers side.
« Last Edit: 17 May 2015, 12:41:57 by Andy A »
« Reply #2 on: 17 May 2015, 12:36:22 »
On my 2.5TD, is this the HBV? It's dripping coolant :-\ ...
The black round thing with a vac pipe out of the top? Yes ..... it's a HBV  :y :y
« Reply #3 on: 17 May 2015, 12:37:42 »
That looks like its a air con pipes.
The top pipe is, but but look lower down  ;)  ;)
P6UL K
  • Dartford, Kent
« Reply #4 on: 17 May 2015, 12:54:34 »
Thanks lads, blue pipe isn't my doing - previous owners responsibility that one! Ok Vx only or are patterned ones just as good?
RobG
    • 16 plate Mokka. Vivaro
« Reply #5 on: 17 May 2015, 13:04:03 »
« Reply #6 on: 17 May 2015, 13:31:55 »
The black "flying saucer" shaped device with 2 rubber hoses going to it, and a small vac on the top is an HBV. Dealer only.  Please note that the TD one is different to all other Omega ones.
P6UL K
  • Dartford, Kent
« Reply #7 on: 17 May 2015, 13:55:37 »
Good to know TB  :y I'll order the correct pipe to replace that blue one and also need belts.
P6UL K
  • Dartford, Kent
2.5TD Coolant Pipe
« Reply #8 on: 22 June 2015, 15:29:52 »
The blue pipe seen in this photo is not oem and I need to replace it as its leaking, it goes from the back outlet on the header tank to the lower of the dual outlets on the HBV.  Would anyone happen to have the correct part number for this pipe?
 I've just been into Vauxhalls and bought a replacement header tank and heater bypass valve but we couldn't find the correct pipe on his part system to link the two together !
« Reply #9 on: 22 June 2015, 16:06:59 »
A TD HBV only has 2 ports, not 3 as other Omegas?
« Reply #10 on: 22 June 2015, 16:11:13 »
This part (from base of header to the transfer pipe)?
7 90448281  13 37 242 HOSE, HEADER TANK TO CONNECTING TUBE   (C)   -11999999
P6UL K
  • Dartford, Kent
« Reply #11 on: 22 June 2015, 16:13:31 »
Well I can only assume this is oem unless a certain someone has fiddled with it!  :D
If you 100% sure I can return the parts for the correct HT and HBV...
« Reply #12 on: 22 June 2015, 16:16:49 »
Anyone got a pick of HBV in their TD?
RobG
« Reply #13 on: 22 June 2015, 16:20:30 »
Diesel HBV
P6UL K
  • Dartford, Kent
« Reply #14 on: 22 June 2015, 16:24:43 »
Diesel HBV
Dear oh dear! Back upto Vauxhalls!  ::)
