A tip for Omega V6 Aux Belts
Started by JamesV6CDX, 19 May 2015, 02:39:06
The size you will be sold is 6Pk2020
They are, in my opinion, just a tad too tight. Indeed some pattern ones seem to strain the tensioner / max it out, which causes undue wear and noise from the aux belt
I have found a great workaround is to ask for a 6pk2050 belt instead. The extra 3cm on the belt makes all the difference, the tensioner sits nice and centrally, and it is much less strained/quieter (but still plenty taught enough, and properly tensioned)
Just my tuppence worth... :y
MV6Gaz
Just about to replace mine, sounds like a useful tip, take it I should replace the tensioner at the same time?
Is there a recommended time/mileage schedule for replacement,and guess its worth carrying a spare?
http://www.mister-auto.co.uk/en/drive-belt/contitech-6pk2050_g305_a0316PK2050.html
05 Volvo S80 D5, 98 V70 TDI, 99 V70 SE
Quote from: MV6Gaz on 19 May 2015, 08:00:55.....,and guess its worth carrying a spare?
Put the old one in the boot  :y
Diamond Black Geezer
Can't report on the 'book' time to replace the tensioner, however I felt there was a slight 'grumble' from my tensioner. Got one from a scrappy which span on my finger for 26 seconds. Took the old one off, and it span for....half a turn.  :o
So worth testing your tensioner whilst off - see how long it spins for and let us know. Swapping the whole belt over can be a bit of a faff, but if, at a later date you swap the tensioner over, that's really straightforward, as the belt's already correctly 'plumbed in' and nothing else needs to come off.  :)
Cant see how a tensioner which is towards the end of its adjustment will be under any additional strain given its a clock spring type unit which applies a constant force over the full adjustment range (by design)  :y
Quote from: Diamond Black Geezer on 19 May 2015, 08:55:26
Not a good test so beware, the tensioner pulley bearing should have some grease in it, if it spins for any length of time there will be none left!  :y
You should rotate it and feel for roughness in the race and listen for noise.
Ah, fair enough Mark,  :) To add to my previous post - the tensioner that came off sounded like a snoring pig "ruhruh...ruhruhhh..."with the odd grindy crunch... also you could feel points where it almost jammed. The new one is smooth and makes no noise.
May end up buying a brand new one which will then allow me a side-to-side comparison.
MV6Gaz
Quote from: Andy B on 19 May 2015, 08:43:31
Thanks but it is visible cracked so I have 2 coming via eBay for 26 quid, brand is Merle, made in Germany so hope quality is ok!
Will update on tensioner condition when job gets done, thanks to all for info guys :y
The tensioner is a long-lasting, reliable part whose life can be extended by occasional simple maintenance.
Or, if you're really worried about it, a new one is cost effective and is likely to last as long as the rest of the car.
Anyone who is paranoid enough to want a spare in the car should buy and fit a new one NOW and then worry about something important.
Quote from: Diamond Black Geezer on 19 May 2015, 09:15:38
The key thing is that if you ge a smooth one which spins for a long time, add some grease!  :y
chrisgixer
Some belts do squeak. Or chirp. I think it's partly to do with Kevlar bead evident in the belt edge. Any other belt may not chirp. Could it be that that's the case with the shorter one?
Quote from: Marks DTM Calib on 19 May 2015, 10:50:11
Which is an easy job.  :y
Does the bearing come apart easy enough, then? I considered doing that before fitting the new one, but it seemed like it was all pressed in at the factory and I'd risk bending it it I levered at it. If I'm being over-cautious then I'll have a stab this weekend  :)
The bearing used is a 2RS type and the rubber seals can be eased out to allow grease to be added before refitting the seal.
Obviously this requires removal of the pulley but, that's only a single nut.
Much appreciated as always. It's been on the car for a matter of days, so will have a look this weekend.  :y
