Author Topic: Sun roof  (Read 1914 times)
EMD
  • Noofhampton
    • 95t
Sun roof
« on: 22 May 2015, 12:41:46 »
Last owner had removed the sunroof fuse  ::)
Put the 5 amp fuse in and it blew straight away !
I put a 10 amp in and it works fine  ??? Apart from it won't
close unless i hold the deflector Down .
I've greased it all up and done 2 resets so why is it blowing
the 5 amp and why won't it close without assistance ?
Omegatitis
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Sun roof
« Reply #1 on: 22 May 2015, 13:02:42 »
The rack and/or channels are probably full of muck or rust. It's probably worth checking the condition of the gear on the motor spindle too.
EMD
  • Noofhampton
    • 95t
Re: Sun roof
« Reply #2 on: 22 May 2015, 13:10:58 »
Ok cheers nick , ill have to have another look . Just wanted to see why they removed the fuse , but at least its working now . Unless its got the ghost sunroof syndrome  ::)
I'd guess its been closed a long time , just a slight just scab on the tips of the deflector ... plus the drain holes are clear  :y
« Last Edit: 22 May 2015, 13:14:53 by EMD »
Omegatitis
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Sun roof
« Reply #3 on: 22 May 2015, 15:35:20 »
Trust youve done the complete reset / recycle thing in all directions.
