Seats question.
Started by chrisgixer, 23 May 2015, 10:31:38
chrisgixer
Will an mv6 seat back, fit on an Elite seat base?
I like the side bolsters on the back of mv6 seats. (Bot not the base its just uncomfortable)
I like the elite base and memory functions.
So obviously I'm thinking about making a hybrid of the two. I'll have to fix the the fuse 14 fault on this particular elite seat base though.
biggriffin
, should be a case of unbolt back,but remember remove the pre tensioner first.
Ive changed subframes,,and plastic trims.
Hoof'land storeman.
zirk
Cant see it fitting myself, the lower bracket hinges will be different, ie lower Electric adjustment (Elite) vs upper mechanical wheel (MV6).
Fit the covers and foam from the MV6 seat to the elite frame... :y
chrisgixer
Quote from: Taxi Al on 23 May 2015, 17:47:00
Old posts would suggest that doesn't work. Iirc Sasanach spent a good while welding up an mv6 frame to take elite motors and buttons.
In other words, the frames are different, according to oof legend.
