New wheels
Started by dbug, 23 May 2015, 21:36:29
Viral_Jim
Quote from: TheBoy on 29 May 2015, 10:17:51
I think your figures shouldn't be too far off to be honest, maybe not quite such a drop as 20%.  Remember, you will still use petrol (warming up, when you run out of gas).  I'd say a 30-35% saving on fuel bill is quite realistic.
You need to fill when nearly empty - short filling or filling when only half empty seems to severely impact MPG, I can only assume quite a lot is lost in the filling process.
Excellent tip, thanks. 30% Saving is great, means itll pay back in <1yr given my current mileage. Should also give me a good idea of range vs tank size. If I understand the guide correctly. Actual capacity of a tank is roughly 80% of nominal capacity?
Quote from: jimmy944 on 29 May 2015, 18:07:59
Correct, so an 80l tank accepts approx. 65l of gas when properly set up (its easy to set tank incorrectly so it takes less or more, which would need adjusting).  I personally wouldn't go below an 80l tank, or if an estate the very biggest you could get, even if you have to raise floor by a couple of inches.
