Bearing / Bush Press
Started by X30XE, 23 May 2015, 22:24:08
X30XE
Omegatitis : [in remission]
chrisgixer
What are you looking to press?
X30XE
Currently V70 wishbone bushes. But longer term any bushes/bearings that get in my way. (within reason).
chrisgixer
At least a 10ton press.
Although iirc Volvo bones are quite reasonable. £50 odd each on a c70
X30XE
£29 for the bushes is more reasonable.  Banger-nomics.  :D
chrisgixer
Like these?
http://oldsite.omegaowners.com//forum/YaBB.pl?num=1232197401/all
X30XE
Like these...
http://www.ebay.co.uk/itm/151492938148
Front ones can't be done with threaded bar  :-\
serek
Quote from: X30XE on 24 May 2015, 00:05:05
Like these...
I done few front bushes on Volvos and must say they not they nice to replace
you need extra long adapters to press them out and in
serek
Quote from: X30XE on 23 May 2015, 22:24:08
Any recommendations?
http://www.ebay.co.uk/itm/321705176391
value for money, just use lots lubricant on tread
have kit like that for about 3 years really do the job
I borrowed a set like that to press my rear wishbone bushes and it made the job very easy!  :y
X30XE
Quote from: serek on 24 May 2015, 00:38:43
Like these...
Hmm  :-\ Looking like it's not worth the hassle vs just throwing some new arms at it.
That red hydraulic press you have by your door... what's that rated to? Any good for this sort of stuff?
serek
Quote from: X30XE on 24 May 2015, 23:41:40
Like these...
best option  :y
hydraulic press its 30 Ton
At work we've a fifty-ton air over hydraulic press that is really good at wrecking car parts! ;D I find my 10ton press at home cheaper to use.
X30XE
Quote from: serek on 24 May 2015, 23:43:56
Like these...
best option  :y
Okidoki. Will do.
Ah, right. I'll not bother pursuing the 12 ton options on ebay then  :(
serek
Quote from: Nick W on 24 May 2015, 23:49:17
need to be very careful as you can damage more then just car parts
