Gearbox swap... AR25 to AR35
Started by P6UL K, 28 May 2015, 19:45:44
P6UL K
Has anyone done this swap recently? Is the guide up-to-date and easy to follow?
Going to be doing the swap in my mates garage and I can do without any niggles! So i need to make sure i have all the necessery parts required otherwise he'll have a non-mobile Omega in the way and i won't be very popular!!
Any hints or tips? Jpat dont sell the brass thrust washer any more as mentioned in the guide.
Varche
Do you need the washer for the AR35?
Tips. The boxes are heavy and have potential to injure if you aren't careful. Two strong blokes shouldn't be a problem.
Make sure you have disconnected the wiring loom from the box. There are several connectors mounted unhelpfully above from memory.
P6UL K
Quote from: Varche on 28 May 2015, 22:32:42
I have no idea if i need the washer or not, just thought i should have one 'just in case'
Myself and another burley mate will be using a gearbox cradle so shouldn't be too bad....
My only issue is that the 'Guide' doesn't seem to indepth and more of an overview?
Varche
Is the gearbox you are putting in a known working good entity?
Need to swap the bell housing if your fitting one from a petrol vehicle to a diesel
P6UL K
Quote from: Varche on 28 May 2015, 22:52:56
Apparently so, I bought it off of SJC on here
P6UL K
Quote from: VXL V6 on 28 May 2015, 23:04:48
I believe the gearbox I have just bought came from a V6, so is it just the Bell housing I need to swap? What talk converter should I use? The one from the V6, the AR25 or the 35?
The TC is very dependant on the engine, so it must match the engine you are fitting to.
P6UL K
Quote from: Kevin Wood on 29 May 2015, 09:22:53
F/L 2.5TD
Quote from: P6UL K on 29 May 2015, 09:29:32
F/L 2.5TD
You need to keep the TD torque converter then. :y
P6UL K
Quote from: Kevin Wood on 29 May 2015, 09:31:13
F/L 2.5TD
So TD torque converter and bell housing swap and that's it...? Sounds to simple lol
Yes that's it, keep the torque converter and bell housing then fit the AR35.
You MUST make sure you unbolt the torque converter from the flex pate BEFORE removing the gearbox and when refitting ensure the torque converter is fitted to the new box and fully seated before offering the box back up to the engine.
P6UL K
Quote from: Marks DTM Calib on 29 May 2015, 09:58:31
Brilliant info Mark, thank you! Is there anything I should be concerned about with the torque converter? Anything serviceable on it?
Sealed unit and to be honest, they just don't go wrong unless they are crushed due to not following the above advice  :y
P6UL K
Fantastic! I can't wait to crack on now!
