Author Topic: 2.2i FL VS 2.6 FL handling and steering feel  (Read 1835 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 30 May 2015, 09:54:25 »
What is different between the 2.2i and 2.6 both FL's suspension, steering rack/box, chassis setup etc?
The steering and handling is so different between the two it's very noticeable. I would have thought both would be similar.
Thanks
Andy A
  • Bristol UK
Re: 2.2i FL VS 2.6 FL handling and steering feel
« Reply #1 on: 30 May 2015, 10:40:23 »
To work on, I find the 2.2i is a much easier engine to work on but the 2.6 is so much better in steering feel and handling/ride than the 2.2i.
Why is this?
« Reply #2 on: 30 May 2015, 13:44:52 »
V6 has servotronic steering... assuming that cars are otherwise identical, same body/gearbox/wheels/tyres/tyre pressures steering box is only difference... :y
GLS, CD and CDX share the same suspension for any given engine, Sport/MV6 should be 15mm lower and taughter, Elite is same ride height as GLS etc but softer sprung with self levelling rear shocks :y
Andy A
  • Bristol UK
« Reply #3 on: 30 May 2015, 14:54:43 »
The better feel/ride difference is nothing to do with the front springs or shocks being different between the 2.2i and the 2.6.  :o
So it's all down to the weight of the V6 engine on the same front suspension that is making it feel more planted on the road and gives it a much smoother ride.  :y
I much prefer the Servotronic steering in the V6 over the 2.2i and the extra weight on the front suspension.  :)  ;D
Thanks Al.  :y
« Last Edit: 30 May 2015, 15:08:37 by Andy A »
« Reply #4 on: 30 May 2015, 16:21:35 »
No just the steering... the springs are different for each engine type :y
« Reply #5 on: 31 May 2015, 18:24:55 »
I have 2.2 & 3.2, the 2.2 is indeed a joy to work on. Everything is so easy, space, access is all good, I really enjoy working on it.
The 3.2 is pig to work on, but does feel nicer to drive. Perhaps the almost 100 extra horses helps?  ;D
All mine run on normal shocks and springs, except the 3.2 has Elite front shocks which are tad softer.
Thing is, given most are what 10-15 years old at least & 100k, they will all feel so different
