Author Topic: Headlight/Tail Light  (Read 7703 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« on: 01 June 2015, 21:00:19 »
Have it up on the screen And its for the drivers side headlight out, But when i turn them on and off i see the light come on for a split second.. So is it not the bulb and that I need a HID headlight ballast unit  :-\
Re: Headlight/Tail Light
« Reply #1 on: 01 June 2015, 21:05:31 »
Swap the bulbs to prove either way
Steve B
  • Leicestershire
« Reply #2 on: 01 June 2015, 21:12:35 »
Ok Rob Will do that  :y
« Reply #3 on: 02 June 2015, 03:23:46 »
If you see it flicker then it's trying to spark up... Ballast is therefore likely ok and bulb is toast... Best replacing as a pair... Tother won't be far behind :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 02 June 2015, 11:22:34 »
As said, probably is the Bulb(s), the ballast units are quiet well built and made to last.  :y
« Reply #5 on: 03 June 2015, 19:26:50 »
HIDs aren't covered by (that part of) check control. So look for other blown bulbs, particularly the 4 rear tail lights.
« Reply #6 on: 03 June 2015, 19:52:05 »
I was going to say that, but couldn't find anything to back it up!
It's only the prefacelift that have a tail & a stop/tail light each side. Facelifts just have a stop/tail.
mka306
« Reply #7 on: 03 June 2015, 19:56:32 »
Very true, as I found out today when checking all my lights were working, the brake light is also the tail light on the facelift.
Steve B
  • Leicestershire
« Reply #8 on: 15 June 2015, 13:25:06 »
The o/s just flickers when turned on so need to swap them over to see what happens
How do i get it out without force  :-\
Steve B
  • Leicestershire
« Reply #9 on: 15 June 2015, 14:02:04 »
Got it...  Push n twist...There Tight
« Reply #10 on: 15 June 2015, 14:38:21 »
[Insert Joke Here]  ;D
Steve B
  • Leicestershire
« Reply #11 on: 15 June 2015, 14:46:50 »
well it was tight thought i would bust it  ;D ;D
Steve B
  • Leicestershire
« Reply #12 on: 15 June 2015, 15:07:17 »
Right what ive just done is what rob said Above..
Went out and swapped the bulbs over,, And yes now its the other side And i could clearly see that the bulb was duff from looking at it,So I need a Set of Bulbs  :y
TB: When i put side lights on everything is fine.When i put dipped beam on...Then i get the Headlight/Tail light Warning on the dash.
Been round and checked all bulbs & Brake lights,There is no other fault,Just the one HID Bulb Which once turned on gives me the Warning.And when i turn back down to side lights only, the warning goes out after a short amount of time..
So unless im missing something..The warning is for the Blown HID Bulb.
« Last Edit: 15 June 2015, 15:09:00 by BIGtime »
Steve B
  • Leicestershire
« Reply #13 on: 15 June 2015, 15:47:16 »
See the Bulbs are not cheap  :D :D Take it the £20 stuff is junk..
What about these http://www.ebay.co.uk/itm/2-x-GENUINE-PHILIPS-HID-D2S-Xenon-Bulb-24-h-DISPATCH-24-Months-WARRANTY-85122-/281204647280?pt=LH_DefaultDomain_3&hash=item41791a6570
Markings on my Bulb Are:-
Osram X Enarc D2S 35W 66040 Germany
« Last Edit: 15 June 2015, 15:56:12 by BIGtime »
EMD
  • Noofhampton
    • 95t
« Reply #14 on: 15 June 2015, 18:40:07 »
 :o :o
I think one of mine is playing up also  >:(
Omegatitis
Page created in 0.023 seconds with 20 queries.
