Temperature gauge randomly drops to zero then back to normal!
Started by Tony Martyn, 02 June 2015, 18:14:01
Tony Martyn
Just recently my temperature gauge has taken to falling to zero, as if the ignition has been turned off, then rising back to normal. Occasionally it falls to somewhere between zero and normal or once it has fallen to zero it rises to somewhere between zero and normal! then it might return to normal, say 95 and remain there for the rest of the trip!
Any ideas anyone? The car is a Y reg 2.2CD 16V.
flyer 0712
Hi and welcome to the forum...if you put your question in the....omega general help section more people will see it and help you  :y
Delroy47
Quote from: flyer 0712 on 02 June 2015, 21:05:28
[/highlight]
Welcome to OOF  :y
MV6Gaz
05 Volvo S80 D5, 98 V70 TDI, 99 V70 SE
Varche
steve6367
The connection is just a spade on a stud at the back of the engine and so can make bad contact - would be a good first item to check certainly.
