Remember when your car battery had just two connections?
Started by The Sheriff, 04 June 2015, 15:23:21
Quote from: Vamps on 05 June 2015, 01:19:19
I couldn't be doing with this new fangled stop/start thingy, defo not for me, it would be like driving a manual....... :( :(
It would be like driving a 1970's Ford, where it would stall at every junction.*
* - for the lucky drivers who managed to get it started in the morning in the first place  ::)
Quote from: Rods2 on 04 June 2015, 17:30:21
Oh aye, such much easier in your youth with hot tube ignition, a starting handle and oil lamps. ::) ::) :P :P
;D ;D ;D ;D
I think you just summed half the membership up ;D
Quote from: aaronjb on 05 June 2015, 12:14:00
;D ;D ;D ;D
Careful! You'll get that DTM bloke over-excited.
https://www.youtube.com/watch?v=vEejYf6cfuE
It would be a bit of a faff at every set of traffic lights, to be fair. I wonder how many shotgun cartridges you'd need to get across Milton Keynes? ;D
Rods2
;D ;D ;D ;D
So much easier for Lord Opti, he just got the butler to walk in front with a red flag. :P :P ;D ;D
Rods2
;D ;D ;D ;D
Anybody else got a copy of my book on modern motor car construction? So we can discuss some of the finer points it is called "Motor Car Construction by R. W. A. Brewer", no ISBN I'm afraid but it was published by Crosby Lockwood and Son in 1912. ;D ;D ;D ;D
Chapter VII - Ignition Mechanism
The ignition of the explosive mixture in the motor car cylinders is now effected by the means of an electric spark. Not so many years ago, engines with tube ignition were still met on the road.....
Electricity may be provided by three different sources in a modern car:
1. Primary dry batteries....
2. Secondary batteries or accumulators....
3. Dynamos or magneto machines.....
The applications of sources (1) and (2) are somewhat identical, as the primary current at a pressure of about four or more volts is conducted round the primary winding of an induction coil.....
They don't make them like this anymore.
4V eh, steady on there!
Do you think R. W. A. Brewer is any relation of Mike Brewer of Wheeler Dealer fame? ;D
