Remember when your car battery had just two connections?
Started by The Sheriff, 04 June 2015, 15:23:21
zirk
Broomies Mate
Quote from: zirk on 04 June 2015, 15:27:52
Still got 2connections just split into fuses.  ;)
Exactly.
Just that set up splits the power distribution where you can see it, rather than further inside the loom where you can't.
The start stop models also have a current measuring shunt in the main connector.
Diamond Black Geezer
Is it right that you can destroy a start-stop car to jump start another, and indeed, destroy the start-stop-equipped car by trying to jump it?
zirk
Quote from: Diamond Black Geezer on 04 June 2015, 16:33:42
Quite possible if you connect it in the wrong place, ie, wrong side of a shunt, or fusible link, I think there Fusible Shunts as well which may or may not help.
Rods2
Oh aye, such much easier in your youth with hot tube ignition, a starting handle and oil lamps. ::) ::) :P :P
Quote from: zirk on 04 June 2015, 17:01:25
BMW X5s tend to react quite vehemently to attempts at jump starting a n other vehicle from the auxiliary battery :D
Mercedes don't like that either. And the original A-class puts the EML on when you jump start them.
Bloody Germans!
YZ250
Quote from: Harris K Telemacher on 04 June 2015, 21:20:29
As the battery on later beemers is hidden in the boot, they are fitted with a 'live post' under the bonnet for jump starting. I've started family members cars/trucks plenty of times with no ill effects to the stop/start thingy.  :y
If this would render the stop/start function inoperative I would happily connect jump leads directly to the battery as I always switch the function off anyway.  ;D
Rods2
It does seem sensible to have the main fuses very close to the battery as it will help minimise the risk of electrical fires and damaged wiring. :y
Quote from: YZ250 on 04 June 2015, 22:06:45....
As the battery on later beemers is hidden in the boot, they are fitted with a 'live post' under the bonnet for jump starting. I've started family members cars/trucks plenty of times with no ill effects to the stop/start thingy.  :y ....
Likewise my Merc  :y
I couldn't be doing with this new fangled stop/start thingy, defo not for me, it would be like driving a manual....... :( :(
