A little quiz
Started by TheBoy, 05 June 2015, 09:18:41
I "broke" my beloved Bullet a couple of days back, when it drifted into one of the many Grand Canyons that Buckinghamshire County Council are trying to make in the north of their country.
It went in with a hell of a clout, "quite" fast, and at an awkward angle, and a couple of seconds later I got a coolant level warning (not to mention an odd pull).
I've investigated this morning, the pull may be due to inflation on tyre, so guess its either knocked some air out of it, or slow punctured it - time will tell, but no visible signs of damage.
The coolant warning though, any guesses?
Float dislodged?
Wire fell off?
All the coolant came out?
flyer 0712
 :y  float dislodged.
The Sheriff
Quote from: TheBoy on 05 June 2015, 09:18:41
Sounds like you've given the front end a right jolt. I thing you were lucky to get away with just coolant warning.
The float has probably tried to escape and got stuck or, knowing your luck, you've loosened the most awkward, hidden joint somewhere deep in the bowels of your motor  ;D
You're lucky you didn't knacker you suspension.........or maybe you did?
Varche
Loom broke off header bottle?
You need No win no claim carbrokenwesuecouncils.com  0800WINALOT  ;D
The Sheriff
Quote from: Varche on 05 June 2015, 13:48:06
I tried that second lot. They sent me a bag of dog food  >:(
The Sheriff
The best way to put this right is to drive the opposite corner into the same pothole. Equilibrium will be restored......honest. Try it  :y
"couple of seconds later" Hmm. ::)
Front wheel punted through inner wing into coolant bottle? ;D
Radiator shock tested to destruction?
Terbs
That happens to my Coolant message. I hit a traffic hump, and bumph....message. Deliberately hit the next hard...bumph....message gone. Have now stuffed finger in tank, waggled shite out of the float....200+ miles, nor warnings :y
The Sheriff
Quote from: terbert on 05 June 2015, 14:02:14
That happens to my Coolant message. I hit a traffic hump, and bumph....message. Deliberately hit the next hard...bumph....message gone. Have now stuffer finger in tank, waggled shite out of the float....200+ miles, nor warnings :y
AHA! My theory has been confirmed. DO IT! Go on....please.... ;D
chrisgixer
Your coolant level sits quite low iirc?
A jolt could have just been enough. Did it cancel and not return? Presume so.
Quote from: chrisgixer on 06 June 2015, 14:40:12
No. It most definitely returned.
chrisgixer
Quote from: TheBoy on 06 June 2015, 15:32:04
Bottle sensor oppsed then.
chrisgixer
Oh, I see admin edits are instant. ;D
Quote from: chrisgixer on 06 June 2015, 15:33:45
Everyone has a quick edit (no notification), then a normal edit (within a set time, but with an Editted note at bottom) ;)
