Author Topic: Never been serviced ?  (Read 4029 times)
EMD
  • Noofhampton
    • 95t
« on: 09 June 2015, 17:43:54 »
So bit by bit the manual 2.5 is coming to pieces , last owner admitted that he never serviced it in 3 years  ::) Strangely all the breather system was NOT blocked  :o not even the small breather on the breather box !
Alas all 6 plug wells were full to the top with oil and the plugs looked like they had been in a good 10 years  :( But it ran a treat !!
Interestingly again were the cam cover gaskets and o rings that were all hard and knackered , but they were stamped GM  ??? Quite a bit more to do but just goes to show that even neglected these engines put up with a lot of abuse .
Omegatitis
deviator
  • Chesterfield
Re: Never been serviced ?
« Reply #1 on: 09 June 2015, 17:59:37 »
I just don't understand it. Even if you paid, a minor service wouldn't be expensive. If you changed the oil yourself, it's less than 15 quid with trade club.
EMD
  • Noofhampton
    • 95t
« Reply #2 on: 09 June 2015, 18:11:31 »
Previous owner wasn't very mechanically minded apart from knowing only where to top the engine up 2 pints a week cos of the cam gasket leakage  ;D
Omegatitis
deviator
  • Chesterfield
« Reply #3 on: 09 June 2015, 18:14:50 »
 :o It would have been cheaper to get it fixed.  ;D
EMD
  • Noofhampton
    • 95t
« Reply #4 on: 09 June 2015, 18:22:04 »
Luckily it was peanuts to buy , apart from a smoke cloud from the cam covers in traffic it ran faultless  ;D Even the a/c is ice cold ! I was expecting worse to be honest but the deeper i delve it dont look too bad  :)
Omegatitis
deviator
  • Chesterfield
« Reply #5 on: 09 June 2015, 18:29:10 »
Sounds like you've been lucky or you know what you are looking for/at.
I can't complain, my Omega was pretty much scrap value and flew through the MOT, advised on front discs and pads and a crack in the number plate.
EMD
  • Noofhampton
    • 95t
« Reply #6 on: 09 June 2015, 18:37:06 »
Yeah there are some bargains out there , far too many just ran into the ground and scrapped for the smallest reason . Most if not all can be saved even if they are not serviced  :y
Omegatitis
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 09 June 2015, 19:08:22 »
My mates Honda Civic had never been serviced in his 6 year ownership.
His cel came on a year ago. VTEC malfunction. Check his oil. Nowt on the stick. 2 litres of oil later... ::)
Since then I've serviced it for him and fitted new rear discs/pads and front discs/pads. Wish I'd have taken a photo of the discs...huge chunks missing causing vibration under braking.
Anyway my point is some folk don't give a shit. His argument being his car is just a white good
RIP Paul Lovejoy
deviator
  • Chesterfield
« Reply #8 on: 09 June 2015, 19:38:07 »
Scary attitude. I've never driven a fridge 50mph, nor would I want to.
Webby the Bear
  • Northampton
« Reply #9 on: 09 June 2015, 19:51:52 »
 ;D very true  :y
RIP Paul Lovejoy
« Reply #10 on: 09 June 2015, 20:10:37 »
An advisory for a cracked number plate... ??? Time for a new tester... ::)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #11 on: 09 June 2015, 21:50:01 »
You need to read all the new mot,guidelines, plus arse covering, etc etc, advise and pass unless its dangerous..
Hoof'land storeman.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #12 on: 09 June 2015, 23:29:17 »
i am disappointed. I thought this thread was going to be about a woman in need ;D
« Reply #13 on: 10 June 2015, 00:31:19 »
Pervert........... :D :D
2boxerdogs
« Reply #14 on: 10 June 2015, 16:51:00 »
.     Thinking of offering your services ?
