Pages: 1 [2] 3  All   Go Down
Author Topic: Brake pads  (Read 11536 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
Re: Brake pads
« Reply #15 on: 12 June 2015, 07:54:24 »
Keith B... I had already inbox'd him to contact you to get these.😊
Re: Brake pads
« Reply #16 on: 12 June 2015, 16:58:26 »
GM pads on TC are around £10 for rears and £15 for fronts (probably plus VAT).
They are a known, tested entitiy, and work very well on all Omegas.
Mintex pads are shite. End of.
Re: Brake pads
« Reply #17 on: 12 June 2015, 18:56:56 »
 .... and here endeth today's lesson  ::)  ;D ;D ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Brake pads
« Reply #18 on: 12 June 2015, 19:52:33 »
Thou shalt count to 3, not to 4, only to 3.
Hoof'land storeman.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: Brake pads
« Reply #19 on: 13 June 2015, 03:30:11 »
When I had oe brakes, they had oe pads.
Tc pads are....ok, for the money.
But do oe pads justify the price? No. They are better, but not that much better.
Corrected ::)
...and yes Tc pads from GM, are £14 odd and work. Some dust, some very slight squeal sometimes in some cases, but they work. Reliably.
Oe pads have less dust and proper riveted shims so don't squeal, and have better pedal feel with better bite. But cost 4-5 times as much if you can get trade on them. Otherwise they are a too expensive, but are the best pads I've had.
You pays your money, etc. :)
« Last Edit: 13 June 2015, 03:37:18 by chrisgixer »
Re: Brake pads
« Reply #20 on: 13 June 2015, 09:07:25 »
Corrected ::)
Not sure its luck of the draw, but OE seem dusty now as well.  She has done 80 miles since I washed it (and changed the pads) and the front wheels had a good layer of brake dust. Or she drives like a bloody lunatic, which she denies ;D. Previous set were dusty as well.
To other people reading, I run one car (the one I use) on TC pads, and other (the one she uses) on OE. Both pads seem to have equal stopping power, both easily have the capacity to fire the ABS in the dry at very high speed. TC ones tend to need a bit of heat in them to become effective, which means the first application on a journey can feel like they are ineffective.  Traditionally, TC ones created a lot of brake dust, but now not convinced there is that much difference. TC ones often need anti squeal grease and a chamfer filed on leading edge, OE rarely do.
OE are probably a bit better (esp for initial 'bite', more so when cold), but not worth the extra price IMHO. Which is made worse then I tend to throw pads away at half worn, as their heat dissipation ability reduces, but not everyone will use their brakes to that extent.
We, on OOF, have proved time and time again that TC pads are suitable for all, can take a good beating, and are very competitively priced on TC.  This is why so many of us recommend them.  A few of us have tried the big name pads, like Mintex mentioned earlier, and been disappointed with them when used in a spirited manner. With TC ones being a known, good option, and competitively priced, why ever choose anything else?
jb
  • bucks
    • 3.2 Elite
Re: Brake pads
« Reply #21 on: 13 June 2015, 11:00:52 »
Oe are best but expensive although give x 2 life of tc pads.Tc are good allround but dusty and lack initial bite from cold.Pagid have good bite from cold but are dusty and wear out fast approx 12 k for the fronts....take your choice
    • 530D M Sport, 330i Coupe
Re: Brake pads
« Reply #22 on: 13 June 2015, 11:07:04 »
I just keep an eye out for OE ones and buy them when at the right price.  :y
Re: Brake pads
« Reply #23 on: 13 June 2015, 12:11:23 »
Yes it's worth keeping an eye on ebay.  I bought a set of OE for £9 delivered a couple of years ago.  :y
Re: Brake pads
« Reply #24 on: 13 June 2015, 12:16:22 »
Shhhhh  ;D
Re: Brake pads
« Reply #25 on: 13 June 2015, 19:50:30 »
Ive damn near a box full of OE sat in the garage ;D
biggriffin
Re: Brake pads
« Reply #26 on: 13 June 2015, 21:14:54 »
Only get 4 pads in a box. Wats a near full box contain :D  ;D
Hoof'land storeman.
gbh
  • forest of dean
    • omega cdx 2.6
Re: Brake pads
« Reply #27 on: 13 June 2015, 22:23:30 »
Delphi pads any good?
MikeDundee
  • Costa Del Peckham
Re: Brake pads
« Reply #28 on: 14 June 2015, 08:24:32 »
Corrected ::)
Had the fronts replaced with OE a few weeks back and notice the same ::)
gbh
  • forest of dean
    • omega cdx 2.6
Re: Brake pads
« Reply #29 on: 14 June 2015, 21:36:13 »
Hi all just bought a set of GM pads off Ebay which come with pins and spring but they are for solid discs £9.95 delivered,hope they are the right ones 9193476
Pages: 1 [2] 3  All   Go Up
