Author Topic: Bonnet release doesn't release  (Read 3437 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 11 June 2015, 13:52:32 »
I pull release lever, bonnet does not spring up, is not open. I place heavy item (wife) on front centre of bonnet. pull lever, bonnet pops up. I open bonnet, adjust cable, test action, slam bonnet, bonnet opens OK. Next morning bonnet will not open. Cable hs not slipped.
Yesterday I moved the slam panel pin a bit away from locking spring. Tested it, OK. This morning, would not open. Puzzling.
All I haven't tried is screwing the pin in or out.
Have I missed something? I am nervous of changing pin length in case I go the wrong way and cannot open the bonnet at all. Please advise.
Diamond Black Geezer
    • & a silly coupe coming...
Re: Bonnet release doesn't release
« Reply #1 on: 11 June 2015, 16:12:47 »
'Pin length', I'm not sure?
If you look above the NS headlight there's a little bracket and a screw, if you slacken this, move/pull on the wire (tot he right), add a little tension, tighten, then try pulling the lever, and keep going trial and error until you're happy. Might have got this all wrong but did this a couple of months and it cured my slack cable and no issues since.  :)
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 11 June 2015, 17:21:13 »
Thanks DBG. That's what I meant by adjusting cable; always worked in the past, not this time. I'm not clear in my head how placing heavy weight on centre front of bonnet always frees it, but it always does. I must give it some more thought.
« Reply #3 on: 11 June 2015, 18:07:11 »
Sticky pin... Apply lots of plus gas then a bucket load of grease...
Then lower bonnet to first latch and bounce it up and down to work the spring...
Then adjust as per guide :y
Possibly also worth adjusting the rubber stops a smidgen in...
« Reply #4 on: 11 June 2015, 21:56:24 »
With bonnet up, watch the moving parts while someone else pulls the lever, the bar can wear and is only a couple of quid to replace, there is a guide...
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #5 on: 11 June 2015, 22:06:52 »
Grease the springy plunger bit and adjust the cable clamp, as the guide iirc? :)
« Reply #6 on: 11 June 2015, 23:02:29 »
Ahh yes, my old car required this fix...
http://www.omegaowners.com/forum/index.php?topic=90677.0
« Reply #7 on: 12 June 2015, 09:09:39 »
Sorry, yes, assumed that the latch mechanism was actually working and greased. Obviously if not - then grease it  :)
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 15 June 2015, 22:33:45 »
Thanks to all for advice. Sadly, cleaning, greasing and adjusting did not work, so I resorted to changing the latch spring. Marks DTM Calib has written a useful guide, and I followed it. It begins 'this is a nice easy and cheap part to replace'. It was cheap enough (£3.65) but not so easy. Perhaps I made hard work of it. It will be easier next time.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 16 June 2015, 09:32:51 »
But did it solve the problem :y
terry paget
    • 3 Astras 2 Vectra
« Reply #10 on: 16 June 2015, 17:50:36 »
Yes, Robson, it's working fine now. Pics attached of old spring, obviously seriously worn and liable to catch. It is also now clear why sitting wife above latch frees it.
https://www.dropbox.com/s/qacsjl04sdkuzxu/latchspringtop.50%25.jpg?dl=0
https://www.dropbox.com/s/eb2v5fdvyxma5vl/latchsprintbottom50%25.jpg?dl=0
