Author Topic: Interior trim  (Read 6843 times)
DezB
  • Derby
    • 52 2.2 CD Auto
Interior trim
« on: 13 June 2015, 16:29:21 »
I expect that this has been asked before but I can't seem to find a definitive answer.
I need to run a usb cable from behind the centre mirror, along the inside of the headlining and down behind either the dashboard or one of the front pillars for a camera.
I've removed the mirror and the centre light unit where there is a perfect gap to run the cable out to the camera but it's the rest of it that I'm having difficulty with
Before I start pulling at the trim can someone tell me the easiest way to remove the trim so that I can run the cable please?
Many thanks
DezB
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Interior trim
« Reply #1 on: 13 June 2015, 19:21:36 »
Do you need the USB cable, or is it just to power the camera? Mine uses a 12v to mini USB adapter wired into an ignition switched live(actually the sun roof wiring)behind the courtesy light. This avoided the need to run the cable across the car, down the roof pillar and behind the dash. Much easier and neater. Cost about 3quid off Ebay
DezB
  • Derby
    • 52 2.2 CD Auto
Re: Interior trim
« Reply #2 on: 13 June 2015, 19:42:20 »
Hi Nick
That's a thought, I don't have a sun roof but guess I could run it off the live feed to the centre light.  I'll take a look on ebay to see what they have got.
Really appreciate your response.
Kind regards
DezB
  • Chatham, Kent
Re: Interior trim
« Reply #4 on: 13 June 2015, 21:02:35 »
DezB
  • Derby
    • 52 2.2 CD Auto
Re: Interior trim
« Reply #5 on: 13 June 2015, 21:55:31 »
Hi All
All your help, Much appreciated.  I'll now tackle this with a lot more confidence.
Best wishes
DezB
    • 530D M Sport, 330i Coupe
Re: Interior trim
« Reply #6 on: 13 June 2015, 22:12:00 »
Just tucked the power feed (and GPS cable) for mine under the headlining and down behind the trim on the A pillar then down the door rubber, under the dash panel and then though a transformer to a live feed.
You don't need to remove the headlining, just tuck the cable(s) up under the headlining, pull the A trim off and tape the cables to the pillar then replace the trim.
Re: Interior trim
« Reply #7 on: 13 June 2015, 22:35:39 »
I referenced the guide as it details how the headlining is mounted... iirc (and I wrote the damn thing ::)) :y
To remove it in order to run a single wire is border line moronic ;D
Personally I would follow Nicks advice and use the sunroof motor loom... it will be taped up as a foam lump... a single 4x2 plug iirc, about an inch across :y it might not be obvious, but it's there...
DezB
  • Derby
    • 52 2.2 CD Auto
Re: Interior trim
« Reply #8 on: 28 June 2015, 12:42:08 »
Hi Harris K Telemacher
I've had a good poke around behind the courtesy light and can only find the wiring as in the photo:
Am I on the right track here, I was thinking of splicing into the red and black on the courtesy lights.  If I could have found the Sunroof plug I could have used that directly. Any idea what the black plug with the brown and red wires feeds?
Thanks again.
DezB
Phil L
  • Hitchin
    • 2003 2.6 Elite estate
Wishing I'd not sold the 67 Mustang...
DezB
  • Derby
    • 52 2.2 CD Auto
Re: Interior trim
« Reply #10 on: 28 June 2015, 17:13:44 »
Hi
This is the one I've just bought, arrived in just a few days, seems to be good quality:
http://www.ebay.co.uk/itm/130978719862?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
DezB
Re: Interior trim
« Reply #11 on: 29 June 2015, 13:24:35 »
Thanks again.
DezB
That's the illuminated vanity mirrors...
Obviously didn't pull the bloody great lump of loom behind it in the pic then... ::)
There are three more plugs up there:
Sunroof loom
Autodipping mirror loom
Rainsensor loom
Keep looking :y
DezB
  • Derby
    • 52 2.2 CD Auto
Re: Interior trim
« Reply #12 on: 01 July 2015, 08:11:59 »
Hi
You're right, I didn't pull anything else out as there is a large block of foam in the way and the last thing I wanted to do was break anything, (it wouldn't be the first time!).
I'll take another look shortly.
Thanks again.
DezB
DezB
  • Derby
    • 52 2.2 CD Auto
Re: Interior trim
« Reply #13 on: 04 July 2015, 18:02:15 »
Hi Harris
You're a genius, found it behind the large block of foam.
Can you please tell me what this plug does and the name of the its opposite type?  I thought I could then wire one up accordingly and just plug it in; simples....
Kind regards
DezB
Re: Interior trim
« Reply #14 on: 04 July 2015, 21:14:02 »
That might supply pos, neg, closing and speedo inputs to the sunroof motor... ::)
As for it's opposite end... That will probably be the, er, sunroof motor ::)
Although that said, that shape plug could also be for the auto dimming mirror loom :-\
Difficult to tell from here,  but I have a feeling that the sunroof motor wiring is a heavier grade pos and neg :-\
Should be another two plugs up there...
« Last Edit: 04 July 2015, 21:17:20 by Harris K Telemacher »
Page created in 0.249 seconds with 20 queries.
