Author Topic: What a job "angry face"  (Read 4519 times)
EMD
  • Noofhampton
    • 95t
« on: 14 June 2015, 21:17:48 »
Replaced/fitted the new gaiters over the manual gear leaver and handbrake , had to dremmel the plastic tabs off the gear stick surround then find staples underneath  ::) Fitting the new one is krypton factor stuff  >:(  >:( >:( >:( re stapling would not work so ended up drilling tiny holes and stitching it back on with framing wire  :D Handbrake gaiter was easier , should not have to be done again for another 10 years or so  ;D
If your thinking of replacing yours , good luck  :D
Omegatitis
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: What a job "angry face"
« Reply #1 on: 14 June 2015, 21:28:18 »
You seem to have made a meal out of it; I had both back on the car in an hour using just some contact adhesive.
The handbrake one went straight on, but the gearlever one needed a bit of trimming around the tabs you cut off, and the seams thinning down a bit. That took maybe five minutes with a single-edge razor blade.
EMD
  • Noofhampton
    • 95t
« Reply #2 on: 14 June 2015, 21:49:53 »
Yes the seams were quite tough and struggled with them , the gear stick gaiter wasnt the best fit but looks very good now with a bit of fetling . I didnt think glue would be strong enough so went for the ultra strong method  :-X
Omegatitis
« Reply #3 on: 14 June 2015, 21:51:53 »
If you've cut the tabs off, then what holds the gaiter to the centre console :-\
EMD
  • Noofhampton
    • 95t
« Reply #4 on: 14 June 2015, 21:57:04 »
I cut the melted on tabs that hold the surround on , no other way of accessing the staples otherwise  :-\
Omegatitis
  • Chatham, Kent
« Reply #5 on: 14 June 2015, 22:06:07 »
Then the auto surround is rather different as the staples are on the outside and easily removed.
As for contact adhesive, a trimmer would use it for sticking a complete headlining to the roof, or to make a door card. If you buy the stuff in a tin, and brush it on, it's seriously strong stuff!
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6 on: 14 June 2015, 22:28:03 »
The set I just bought are going back as the handbrake gaiter 'neck' is double the required size. I see other types available at a higher price, will try again. >:(
« Reply #7 on: 14 June 2015, 23:02:01 »
Put me off changing mine, I'll just keep the 'distressed' look  ;D
« Reply #8 on: 14 June 2015, 23:07:52 »
Duct tape is quick and easy!  8)
EMD
  • Noofhampton
    • 95t
« Reply #9 on: 15 June 2015, 09:57:44 »
I wouldnt recommend the set i bought either , although both
items were well made .. fitting takes some doing .
I noticed the ones taken off were fake leather look  ::) Possibly fake for a reason
as they fitted much better .
Omegatitis
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #10 on: 15 June 2015, 16:06:10 »
Did anyone buy the ones made by the chaps I suggested/recommended? If so, then apologies, as bought two or three gaiters off them in the past with nothing but 10/10 for fit and quality :(
EMD
  • Noofhampton
    • 95t
« Reply #11 on: 15 June 2015, 18:01:54 »
Dont think it was the one you linked to dbg , i just went pot luck pattern ..
Omegatitis
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #12 on: 15 June 2015, 21:24:32 »
I used a black Magic Marker ;) looks better than before anyway :y
« Reply #13 on: 15 June 2015, 21:53:07 »
Hummm. I have a black sharpie on the garage :)
Shackeng
  • Ramsbury
« Reply #14 on: 15 June 2015, 21:56:26 »
Got mine from Topgaiters, not recommended from the ones I got which go back tomorrow.  :(
