Headlight lens cleaner
Started by EMD, 17 June 2015, 22:11:12
EMD
So many products on the market to make you headlight lenses crystal clear  ::) Ive tried one and it was rubbish ! Cant recall the name of it now , any product anyone has used and can recommend that actually works please  :)
Omegatitis
3M Headlight Restorer kit has everything you need bar the drill....  :y
Buy a sheet each of 1000 and 1200 wet and dry paper. A sheet of 1500 if you can find it might be worth having.
Use on a small block and with lots of soapy water.
Then buff them up with your favourite abrasive polish; something coarser than T-cut if you can.
Some masking tape on the wing edges and on the bumper is a good idea.
I brought both of mine back from dull and very yellow in under an hour, on the car in the dark.
Quote from: VXL V6 on 17 June 2015, 22:55:38
I've used this too, with great results. Enough in the kit to do 2 sets.
2.2 came out really well, must do the 3.2's headlights too
I was watching a fella clean up an 03 Renault clit's very yellow headlights to crystal clear the other day and he was just using T-Cut.  :y
He used a fair bit of elbow grease as well mind.  ;)
deviator
I use an abrasive toothpaste mixed with T-Cut and various grades of W&D. Finished off with a polisher.
EMD
Thanks for all the recommendations folks , the stuff that didnt work
smelt like tooth paste  ;D
Omegatitis
MikeDundee
I done my headlights a couple of weeks ago using the Maguire kit from Halfords, worked a treat :y
I too have used the 3M kit with very good results. Need to do the other car when I get home.
biggriffin
Quote from: Nick W on 17 June 2015, 23:01:29
As above, I finished mine with solvol auto metal polish, and final polish with some mer.
Hoof'land storeman.
