Dash removal "angry smiley face"
Started by EMD, 18 June 2015, 17:56:04
EMD
 ;D
Fl center dash fascia removal and radio removal ! The radio would not budge as the double din pins would not grip  >:( Then did what it said in the guide , filed the pins and it came out after 20 odd attempts  ::) Then krypton factor trying to figure out how the panel switches unhook  ::)
Many a swear word was coming out the windows  ;D ;D Now to get it back in without scratching the paint  ::)
Omegatitis
Apart from the hazard switch, all the others simply pull out... Sockets unclip and slide out ???
EMD
Quote from: Harris K Telemacher on 18 June 2015, 17:58:48
Yeah but i'd never done a fl one before  ::) ;D I found the location of the d/din pins were out of align so god knows how it unhooked itself  ??? Bent the pins into the correct position now .
I cant remember how it all goes back now  ;D
If i scratch it putting it back grrrrr  :-X
Omegatitis
I can only presume that the far inferior prefacelift is assembled using nothing more than gravity and sticky back plastic... :D
minifreek
Don't forget the blutac and sellotape..... thats what I found at the back of mine when I rewired it to receive a proper radio instead of the Bose radio that was installed....
D.I.L.L.I.G.A.F...
omegod
I have resorted to crowbars in the past to remove the DD facelift radio
EMD
Picture as promised , turned out ok . The wood effect had all faded and lost its gloss so went for that rare silver effect . New gear stick and handbrake gaiter's  :y
Omegatitis
You do of course realise that Facelift wood trim comes as either matt or gloss depending on age don't you... ::)
EMD
Wood trim was really bad shape though , car just needs a valet
now .. 2 tyres an all done .. mite even take it Billing  ;)
Omegatitis
