Original battery or replacement battery?
Started by Field Marshal Dr. Opti, 20 June 2015, 14:58:20
I've just lifted the cover on my dreary old Signum to find the battery is a Bosch 74 A/H unit.
Original equipment or replacement?
I was under the impression that all Vauxhall cars came from the factory with GM branded batteries.
I'm hoping it is a replacement as the car was registered in July 2007.
chrisgixer
It's happened again. A post comes up on a subject just as I'm thinking of it. Oof is telepathic at times :y
If Dr doesn't mind, can I ask, what sets the criteria for battery type? Amp hours and all the other numbers printed on the top..?
Mine has a 70 ah fitted. Will that cover all eventualities like short journeys and long stay car parks at the airport etc?
Is there better available? Within the dimensions of that battery box of course as a bigger one won't fit.
The Sheriff
We wouldn't have these problems if Duracell made car batteries. ;D
pauls
Quote from: STMO on 20 June 2015, 22:08:26
they do....
chrisgixer
The Sheriff
Quote from: pauls on 20 June 2015, 22:10:25
they do....
They do? Well........what an informative forum this is. ;D
chrisgixer
ronnyd
Broomies Mate
Major Opti - The Bosch battery will be better than what was supplied from the factory, so be thankful that the previous owner spent a few more quid than necessary on keeping her in good condition.
Bigron
Assuming that your 74 A-h battery still has that capacity (reduction takes place over time....), and your quiescent current drain is the typical figure of 80 mA, it will take 925 hours to discharge it from full in your airport car park - in other words, 38.5 days.
That amounts to a long holiday!
;D
Ron.
Quote from: Broomies Mate on 20 June 2015, 23:09:00
I've no idea when the battery was changed but I'm guessing the original GM battery should last 3 or 4 years as a minimum.
This suggests the new battery is 'relatively recent'.
I'm pleased about this because I've noticed the front tyres are significantly worn. Three hundred miles ago they seemed fine. :'(
Broomies Mate
Quote from: Doctor Opti on 20 June 2015, 23:32:53
Tell me about it!  I have driven the 2.8 V6 in Saab form, and it's a bit of an animal.  You are welcome to try my 4pot and see how that compares!  Bring a spare set of kecks though!  ;D
Mr.OmegaMan
