Loss of coolant and difficults in getting back to normal temperature
Started by fcc-pt, 26 June 2015, 18:20:53
fcc-pt
Loss of coolant and difficults in getting back to normal temperature in hot days.
The temperature raises to 95cº while running at 80km/h, even gets a little lower above 100km/h.
No oil in water no water in oil, no signs of water in the exhaust system!
The big hose that connects the engine to the radiator gets hard and the leak is not perceptible.
I can see remains of coolant on the engine starter...
I've changed the timing belt kit and water pump.
Coolant changed etc etc.
I've got the main vaccum hose broken, does it matter?
What's happening?!?
chrisgixer
Quote from: fcc-pt on 26 June 2015, 18:20:53
No oil in water no water in oil.
What's happening?!?
Starter is right ( as you sit in the car) rear in the engine bay, as is the hbv which is sited above it. Heater by pass valve is a very common failure and cause if water leaks on omega.
While the leak may not be too bad, it "may" still be allowing the system to depressurise enough to allow the temp to rise. Although a rise in engine temp is not something I personally would associate with a leaky hbv. ....so it may just be a leak in that area.
What year is your mv6?
fcc-pt
1998
Left side driver seat, starter in on the left I guess...
What's hbv?
Phil L
Wishing I'd not sold the 67 Mustang...
Quote from: fcc-pt on 26 June 2015, 18:36:28
1998
What's hbv?
Starter still on right... Only steering wheel, brake servo, wiper motor and pollen filter are sided ;)
fcc-pt
Quote from: Harris K Telemacher on 26 June 2015, 18:52:06
1998
What's hbv?
than i guess it's the alternator... :o
either way i see remains of coolant on the left side (seated position)
Heater Bypass Valve needs vacuum to operate?
chrisgixer
Yes. It's activated by the ac, so to test it needs vacuum and the climate control cycled from hi to lo while checking for coolant leaks.
fcc-pt
Quote from: chrisgixer on 26 June 2015, 19:14:59
So I supose if vacuum is broken then the valve won't work.
Does the valve affects the temperature or it's only there for AC?
Is this the valve?
chrisgixer
Quote from: fcc-pt on 26 June 2015, 19:24:43
With no vacuum the valve will only flow through one port. It needs vacuum to move the flow to the other outlet port. It switches flow away from the matrix when ac is on, As I understand it.
You could apply vacuum manually or by other means. Say attach a hose and suck.
chrisgixer
Quote from: chrisgixer on 26 June 2015, 19:28:18
To the vacuum nipple on the hbv I mean, not a coolant pipe. Yuck ;D ;)
fcc-pt
niples  :D
I need the hose that goes from the inlet manyfold to the brake servo.
Where can I get it?
Bigron
Um, ignore me if I'm being stupid, but doesn't a hard radiator top hose suggest a head gasket problem?
Ron.
fcc-pt
Quote from: Bigron on 26 June 2015, 19:45:02
Ron.
hope not, but there is a huge probability
fcc-pt
chrisgixer
1998
What's hbv?
1998(/99?) do tend to suffer hg issues. Usually left side behind the dis PAC bracket behind cylinder 6. But i guess it's best to count out the simple things first.
