Author Topic: 3.2 ets e bay exhaust  (Read 2975 times)
0795omega
« on: 09 July 2015, 14:29:46 »
hi everyone just ordered one of these as mines failed the mot on exhaust,e-bay link is 150810088414 question is garage asked me to make sure gaskets are included,i cant make out from their ad if this is so,can anyone let us know whats what please and if not where to get them from instead? kind regards
Re: 3.2 ets e bay exhaust
« Reply #1 on: 09 July 2015, 14:38:39 »
The only gaskets go between Engine and Cats. Which i presume you are not touching.
Just exhaust paste on other joints :y
amba
  • Medway towns
    • German V6
« Reply #2 on: 09 July 2015, 15:11:23 »
As said only joining paste and clamps. Gasket is for the down pipe to manifold and assume thats not being touched.
Have an ETS fitted on mine now for the last 6 weeks.(2000 miles) ??? and has been faultless and as quite as OEM so very pleased and price was incredible. ;)
0795omega
« Reply #3 on: 09 July 2015, 22:03:04 »
yes cats are staying put,i see it says in the details comes with clamps,so garage fitting it should be getting all they need then? surely they will have some exhaust paste knocking about! thanks
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #4 on: 10 July 2015, 00:37:37 »
The exhaust sections are fine but the fitting kit isn't the best. They may want to use different clamps, and will more than likely need cat bolts, so worth a trip to vx or a factors to get some of those.
mka306
« Reply #5 on: 10 July 2015, 07:21:51 »
It lists the parts in the description
The object of the auction is:
2 x Clamp (code: 250-454)
8 x Rubber Mounting (code: 255-095)
4 x Nut (code: 258-038)
4 x Washer (code: 258-117)
4 x Bolt (code: 258-840)
1 x Exhaust Central Silencer (E type-approval: e3 03 10145)
1 x Exhaust Rear Silencer (E type-approval: e3 03 10141)
You have put 3.2 in the thread title and it states this is for a 3.0, not sure if you spotted that or not?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 10 July 2015, 08:04:32 »
These exhaust fit well, is worth getting the flanges drilled out and use nuts and bolts, the clamps for rear box have been known to be the wrong size.
Hoof'land storeman.
