Author Topic: Wanted Air con compressor pump  (Read 6488 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
« on: 10 July 2015, 15:16:54 »
I think I need to replace the compressor not just the seals but garage is charging £130 for fitting new seals testing and re gassing but they want £260 if the compressor needs replacing based on me sourcing a second hand WORKING compressor.
I've seen some on ebay for £25 but I would rather buy of a decent person on here that is not going to fleece me for a broken one.
Anyone help I would really appreciate it!
www.impactcls.co.uk - Flight Case Manufacture
Impact Pete
  • Derby
Re: Wanted Air con compressor pump
« Reply #1 on: 10 July 2015, 15:24:10 »
scrum that Ive seen them for £15 delivered
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #2 on: 10 July 2015, 16:45:06 »
So there is no gas in the system, they have a ramp and want £260 to undo 4 bolts and two pipes and unplug it, fit  another one and re-gas. I'm in the wrong job.
Impact Pete
  • Derby
« Reply #3 on: 10 July 2015, 18:40:03 »
£45 an hour cheap compared with some garages in derby and their database for that part says 4.2hours I'm sure its a lot quicker!
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 11 July 2015, 07:17:10 »
Like to know were these are from, as compressor seals,I cannot find.
Hoof'land storeman.
Impact Pete
  • Derby
« Reply #5 on: 11 July 2015, 08:01:38 »
Vauxhall part not sure the number but same as vectra I think
biggriffin
« Reply #6 on: 11 July 2015, 08:51:15 »
O, rings or the seal kit, bit different,
O, rings for the pipe to compressor readly available.
Shaft seal,or body seal been told nls, as its usually the shaft seal that leaks.
Google Harrison v5 air con compressor.
Hoof'land storeman.
Impact Pete
  • Derby
« Reply #7 on: 11 July 2015, 08:57:59 »
quote author=biggriffin link=topic=131467.msg1684665#msg1684665 date=1436601075]
[/quote]
When I say seals that's what I mean readily availble for less than £5
Shame no one has replied with an actual offer of what asked in first place everyone just seems to question the detail of what I have written.
I just want an oof member to sell me a used working part :(
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #8 on: 11 July 2015, 12:09:30 »
[/quote]
I have a 3 com pressures here but at this point I have no idea if any are working as all the cars had no gas in them sorry.
Impact Pete
  • Derby
« Reply #9 on: 12 July 2015, 09:16:36 »
[/quote]
Thanks problem is I don't have time to do job so unfortunately have to go to garage but if I supply part it has to be working otherwise it would cost even more longterm, I nearly bought one on ebay but after ready oofs guide to replace I noticed it wasn't right even though seller insisted it was, the engine mounting holes were sideways through the compressor rather than on a V6 being through front from pulley
Don't suppose any one has correct part number to habd for V6 elite?
« Reply #10 on: 12 July 2015, 16:18:44 »
PM sent :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #11 on: 22 July 2015, 14:06:03 »
Did you get a compressor Pete - I have one here but I didn't have gas in the system so I can't be sure it's pressure tight.
Impact Pete
  • Derby
« Reply #12 on: 23 July 2015, 10:29:12 »
Hi no I didn't but just a few hours ago I had the car retested and at this decent garage they found 4 separate leaks, on condenser, a pipe and the compressor so not worth fixing, they are going to try a rad weld type mixture to see if it seals from within but it's a big gamble we shall see
sjc
  • Alloa, Scotland
« Reply #13 on: 23 July 2015, 10:36:52 »
The condenser tends to be the weakest link due to age deterioration and they are a bit of a pig to replace in my opinion.  When I changed the engine an gearbox on mine, I binned the entire AC system  :D
Best of luck!
Impact Pete
  • Derby
« Reply #14 on: 23 July 2015, 10:39:30 »
Best of luck!
cheers, I'm hoping this stuff they put in will at least work for a month! as I dread a long car journey in August with 2 kids under 3!
