Author Topic: cannot open or close windows  (Read 6050 times)
    • 530D M Sport, 330i Coupe
Re: cannot open or close windows
« Reply #15 on: 12 July 2015, 09:59:14 »
Worth popping the drivers door window switch panel out and reconnecting the plug?
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #16 on: 12 July 2015, 11:22:12 »
Thanks for suggestion. This a PFL Omega. There is no drivers door switch panel, all switches are in the car centre.
terry paget
    • 3 Astras 2 Vectra
« Reply #17 on: 12 July 2015, 11:30:00 »
Job jobbed then... ;)
Sadly no. Now I cannot open the windows.
Bugger. Fix the check strap and then deal with thelectrics ;)
My sentiments exactly.
This morning I fixed the check strap, and reassembled the door. Checked the windows, now they work!
I don't understand it, but never mind, there's lots I don't understand. My thanks to all for advice.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #18 on: 12 July 2015, 11:39:21 »
This is where having a power probe is a god send (currently learning how to use one properly)
You can search for power and ground and also supply power to components this verifying operation.
RIP Paul Lovejoy
« Reply #19 on: 12 July 2015, 17:47:07 »
Is the check strap the door grounding point :-\ thinking out loud...
terry paget
    • 3 Astras 2 Vectra
« Reply #20 on: 12 July 2015, 17:56:46 »
I don't think so, especially with the plastic washer at body end it would not be a good choice. When the window finally did close on remote button held down it motored all right. I suppose there is an earth wire in the harness.
Yet there is a mystery why it did not work last night but it does today. Thanks again for your help.
terry paget
    • 3 Astras 2 Vectra
« Reply #21 on: 12 July 2015, 18:57:19 »
Furthermore, until I replaced it there was no electrical connection via the check link.
« Reply #22 on: 12 July 2015, 19:00:19 »
If it happens again, it might be worth pulling the door off and checking the body loom carefully for evidence of breaks... :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #23 on: 12 July 2015, 20:54:01 »
Thanks, will do. I wonder if I somehow upset the central locking ECU by trying to raise the window with a door open, and it went into a sulky routine. I have had similar trouble if I open the boot of a locked Omega with the key. I hate these ECUs with memories. There are ways of resetting memories on radios and CD players, I expect there are on the car ECUs too, but they are not in the handbook.
terry paget
    • 3 Astras 2 Vectra
« Reply #24 on: 18 July 2015, 07:44:53 »
Just to add, after 300 miles of motoring the windows have nor failed again, so I still suspect some ECU problem. On a non Vx note, last night in the pub after tennis in Oxon, Chris Lowry said he could not stay, his Honda S1000 had a problem, he could not close the n/s window so car was insecure.
