Author Topic: cannot open or close windows  (Read 6049 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 11 July 2015, 17:54:46 »
PFL 2000 2.5 petrol manual CDX estate. I am striving to repair the driver's door strap. Have removed door card. It would help if I could close the driver's door window, but it doesn't work. Ignition on, engine running, the front door windows do nothing. They worked before. Fuse 7 is OK. What could it be?
Re: cannot open or close windows
« Reply #1 on: 11 July 2015, 18:04:01 »
Fuse #1 ok?
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 11 July 2015, 18:34:17 »
« Reply #3 on: 11 July 2015, 19:24:56 »
Drivers door loom and window switch still connected... ::)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 11 July 2015, 19:32:32 »
To check voltage to the motors etc, do they wind up with the lock up procedure, ie lock car and hold down remote fob button or key in the door lock
 fully left and hold.
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 11 July 2015, 19:44:42 »
Seems to be. The courtesy light remained on until I removed it. I had disconnected the door mirror adjuster, but on reconnecting,  it adjusted the door mirror satisfactorily, with satisfying whirring noises.
terry paget
    • 3 Astras 2 Vectra
« Reply #6 on: 11 July 2015, 19:47:49 »
NO they don't. However the driver's door locks and unlocks, inferring that the loom is connected OK.
« Reply #7 on: 11 July 2015, 19:51:06 »
Drivers door open or closed? If open retry closed ;)
« Reply #8 on: 11 July 2015, 20:04:21 »
Drivel removed.
Be helpful, not insulting, or shut up.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 11 July 2015, 20:24:00 »
Door was open. Closed door, tried again. Window still does not close.
Probably not relevant, but this morning I removed the scuttle, and it is still removed.
« Reply #10 on: 11 July 2015, 21:04:20 »
Ok, recheck that everything is connected, shut all the doors and lock with the remote... Keep the lock button pressed and report back...
terry paget
    • 3 Astras 2 Vectra
« Reply #11 on: 11 July 2015, 21:15:10 »
Doors locked, window closed.
« Reply #12 on: 11 July 2015, 21:36:55 »
Job jobbed then... ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #13 on: 11 July 2015, 21:50:48 »
Sadly no. Now I cannot open the windows.
« Reply #14 on: 11 July 2015, 23:23:42 »
Bugger. Fix the check strap and then deal with thelectrics ;)
